antanae problem
Old Aug 26, 2001 | 04:43 PM
breaker's Avatar
Unhappy antanae problem
does anyone know where i can get a really good but shorter antanae than the stock one? My current garage can barely accomodate my truck but the antanae is getting bent all the time. I would like a shorter one but not one thats made of rice.
Old Aug 26, 2001 | 09:28 PM
logical's Avatar
www.shortyantennas.com
yes, really
sell a black powdercoated 15 inch billet job, but with the adapter and shipping cost about 30 bucks
better that those rubber rice jobs though
Old Aug 27, 2001 | 02:08 PM
Hollander's Avatar
Hi!
My '98 4X4's radio aerial constantly scraped the roof of the parking structure where I work. Simple solution, I went to my ford dealership and purchased the telescoping antenna that came standard on older Ford Econoline vans. It is a direct replacement part and screws into the stock F-150 antenna base. I can get the Part # if you want, but a competent parts person @ your dealership should be able to find it for you. It costs a whopping $10 bucks! At full length, it's a little shorter than the stocker, but even retracted, still pulls signals well.
Old Aug 27, 2001 | 04:29 PM
fourhour's Avatar
I had the same problem as Hollander as mine was scraping metal signs in the garage. I unscrewed it and cut about 4" off. Cannot notice any difference in reception. ennis
Old Aug 27, 2001 | 10:35 PM
LakeSands's Avatar
Thumbs up
Pull off the little ball with some pliers, cut the antenna with side cutters or hacksaw and stick the ball back on. Spray on a little paint and you're ready to go in and out of the garage w/o scraping.
Old Aug 30, 2001 | 01:01 AM
TRAY's Avatar
Talking
I did exactly what Lakesands did. You would never know and the antenna is still slightly above the top of the cab.
Old Aug 30, 2001 | 07:28 AM
kbrode's Avatar
Cool
I had the same problem at my parking garage. Billet makes several styles of 18" ( I think) antennas. They are not quite as high as the cab. I think I had $28 in it with shipping. I didn't notice any difference in reception.
Old Aug 30, 2001 | 09:45 AM
T Ellenberger's Avatar
Radio Shack. Less than $10 and comes with adapters to match the different makes of vehicles.
Old Aug 30, 2001 | 12:57 PM
MN2001F-150's Avatar
Talking
I use my antenna as a measuring stick for clearance purposes, it's right at 7.0'. So I know if the antenna makes it under, or slightly scrapes, the rest of the cab will be fine! You never know if some of these parking ramps may be marked incorrectly...I'd rather fix a bent antenna then take the truck to a body shop for roof repair.
