Tint Application Solution Question
Old Oct 1, 2010 | 10:13 PM
triathlonrunner's Avatar
I've heard that people use soap and water, but in what ratio?
And also, any tips on putting a brow on the windshield?
Old Oct 2, 2010 | 01:55 AM
Sundevil2188's Avatar
make sure and use unscented, uncolored baby soap. As far as how much, really depends on what size sprayer you are using. In our spray bottles, i usually just eye ball it.
For doing a brow, lay the factory edge towards the bottom and make your cut across the top and sides. that way when you put it in, you have a nice, smooth edge.
Old Oct 2, 2010 | 02:02 AM
b2therad's Avatar
I would lay it out on the outside of the window making sure to spray plenty of window cleaner or application solution/whatever you call it and use a heat gun and a edge to make it smooth. Then cut it to the size you need. After that, then use alot of solution on the inside of the window and peel the sticky side and get it up there. Start from the middle and work your way to the outer edge and trim the extra as needed. Its not difficult or anything, just make sure that you dont get any hair in between the tint and the windsheild.. creases in tint are a pain. I got mine pretty big, which I love. I used limo to make mine.
Old Oct 2, 2010 | 04:01 PM
Drick's Avatar
Fill up a bottle with water and add a few drops. Thats your ratio lol
