Taillight Bulbs
Old Jul 11, 2010 | 10:39 AM
Dinggus's Avatar
Taillight Bulbs
What kind of taillight bulbs do you use? My driver side taillight went out and just curious what everyone uses such as just any bulb or what?
Old Jul 11, 2010 | 11:16 AM
should be a standard 3157 dual filament bulb
Old Jul 11, 2010 | 11:31 AM
Dinggus's Avatar
I thought I read awhile back people used chrome ones as well.
Old Jul 11, 2010 | 11:42 AM
DarkShadowSTX's Avatar
If you want to know what I put in my truck yesterday, here you go.
http://www.v-leds.com/Exterior-LED/B...-p7470633.html
Any 3157 bulb will work though. I needed these so my tinted tails are more visible in direct sunlight. Bright as hell is all I can say.
Old Jul 11, 2010 | 12:02 PM
ELVATO's Avatar
They use those for the front turn signals on the 04-08 trucks.
Old Jul 11, 2010 | 12:13 PM
92 leds in one bulb hot damn! And that thing fit in a tail housing? Nice. I had to trim a minor little bit to get my big reverse bulb LEDs to fit.
Did you have to use resistors to repair any rapid flash? Much brighter than OEM? as in the background glow off area?
Old Jul 11, 2010 | 12:25 PM
sampson01's Avatar
i run 40 LED reds in the blinkers/brake. darren what bulb you running in your reverse? i need more output since my lights are smoked
Old Jul 11, 2010 | 01:49 PM
Fit in the housing no problem. I already had the new electronic flasher from when I put in my 60 LED switchback turn signal bulbs so rapid flash is gone for good. Fills the background much more than OEM and is a lot brighter in the daytime which is what I needed, since stock bulbs suck in tinted tails.
Old Jul 11, 2010 | 04:35 PM
Nothing will be brighter than stock bulbs in the reverse housings, my LED bulbs look better but barely light up at all, and they are 40LED bulbs too in cool white.
Reverse bulbs are for show/alert others in these F150s.
Old Jul 11, 2010 | 06:07 PM
X2. I also have leds as my reverse bulbs and they aren't that bright. Before that I had Sylvanias and they weren't any brighter than stock. My leds match so that's all that matters to me.
Darren: Stock tail bulb on left and LED on right
[IMG][/IMG]
Old Jul 12, 2010 | 11:41 AM
^^those are impressive!
Old Jul 12, 2010 | 01:08 PM
Yea they are. I could only imagine how bright they would be in non-tinted tails. BTW that pic is only running lights so the brake lights are even brighter.
Old Jul 12, 2010 | 04:24 PM
you have the LOF on with running lights? Seems kinda weird im used to seeing them as only brake/blinker
Old Jul 13, 2010 | 06:33 PM
thatoneguy_10's Avatar
Where do you buy your led bulbs? I'd like to replace mine so that they match my light bar under the tailgate. Also,? how many leds would you recomend for lights that are not tinted?
Old Jul 13, 2010 | 07:29 PM
I bought all of my led replacement bulbs from v-leds.com
http://www.v-leds.com/Shop/Control/f.../user/velocity
As far as how many leds, check out all of the options and read the specs for each one. Some are hi-power bulbs and others just have a large amount of leds. What I normally look at when I buy anything online are the product reviews. They can tell you a lot about a product. I got the bulbs I have because someone else reviewed them and had pictures of them in their tinted tails showing how bright they were. You could get away with bulbs with fewer leds but I guess the main factor would be how much you want to spend. My bulbs were $70, but I used a coupon back on Father's Day for 15% off so that helped.
