f150 towing mirrors ?
Running a wire for the puddle lamps is not a problem at all.
Hey, I just got a reply and sent one as well. Here's what has transpired so far:
Orginal Message:
Date: Thursday, October 14 2010 08:59 AM
Subject: Towing mirror accessory kit
Order Number: W/o signal - Accesory kit-towingAccesory kit-towing
What is included in the above kit? Is this a direct bolt-on kit that you guys have put together for these trucks? Im very interested if so, and know others that will be.
Thanks,
David Walker Part Number: 4L3Z17696CA
Reply Sent:
Date: Friday, October 15 2010 11:21 AM
Subject: RE: Towing mirror accessory kit
this kit is only intended to convert standard power mirrors to telescopic mirrors with power glass.
Matt
Message Sent:
Date: Friday, October 15 2010 11:52 AM
Matt,
So what does it include? The kit is $120 roughly above the price of just the mirrors, it appears. Several folks on the f150online.com forum are interested in these kits, possibly. Thanks for your help.
David
I'll keep ya'll posted as I lear more.
David Walker
Orginal Message:
Thanks,
Reply Sent:
Matt
Message Sent:
Matt,
David
David Walker
Take a look at the list below and if there is something you need, feel free to PM or e-mail me at jlaliberte@tasca.com w/ any questions you may have.
I also have the wiring diagram so that all the mirrors listed below can be used on any year F-150 from 2004-2010. It is below the list.
thanks guys!
**2004-2006
Manual
(RH) 8L3Z-17682-DB - $62.37
(LH) 8L3Z-17683-DB - $61.50
Power
(RH) 8L3Z-17682-EA - $116.41
(LH) 8L3Z-17683-EA - $115.38
Power, Heat & Signal
(RH) 6L3Z-17682-CA - $148.23
(LH) 6L3Z-17683-CA - $148.46
Power, Heat, Power Fold & Puddle Lamp
(RH) 6L3Z-17682-GA - $296.03
(LH) 6L3Z-17683-DA - $295.70
Power, Heat & Signal-Chrome (Mark LT)
(RH) 6L3Z-17682-HA - $174.68
(LH) 6L3Z-17683-EA - $174.44
**2007-2010 Telescoping Trailer Tow Mirrors
Manual
(RH) 7L3Z-17682-BB - $120.45
(LH) 7L3Z-17683-BB - $120.45
Power, Heat, Signal & Puddle Lamp-Black
(RH) 7L3Z-17682-AE - $134.75
(LH) 7L3Z-17683-AE - $134.75
Power, Heat, Signal & Puddle Lamp-Chrome
(RH) 9L3Z-17682-EA - $170.21
(LH) 9L3Z-17683-EA - $170.21
Power, Heat, Signal & Puddle Lamp-“Paint to Match”
(RH) 9L3Z-17682-CAPTM - $308.40
(LH) 9L3Z-17683-CAPTM - $305.70
**2007-2009 Standard Mirrors
Manual
Power
Power, Heated, Signal & Memory-Chrome
(RH) 8L3Z-17682-BA - $192.90
(LH) 7L3Z-17683-BC - $315.51
Power, Heated & Signal-Black
(RH) 8L3Z-17682-FA - $151.32
(LH) 8L3Z-17683-FA - $268.91
Power, Heated & Signal-Chrome
(RH) 8L3Z-17682-GA - $172.24
(LH) 8L3Z-17683-GA - $291.92
Power, Heat, Signal, Power Fold & Puddle Lamp-Black
(RH) 8L3Z-17682-HA - $289.20
(LH) 8L3Z-17683-HA - $407.83
Power, Heat, Signal, Power Fold & Puddle Lamp-“Paint to Match Cap”
(RH) 8L3Z-17682-SA - $311.05
(LH) 8L3Z-17683-SA - $428.71
Power, Heat, Signal, Power Fold & Puddle Lamp-“Paint to Match”
(RH) 8L3Z-17682-TA - $333.42
(LH) 8L3Z-17683-TA - $452.06
Power, Heat, Signal, Power Fold & Puddle Lamp-Chrome
(RH) 8L3Z-17682-AA - $332.37
(LH) 8L3Z-17683-AA - $451.03
**2010 Standard Mirrors
Power, Less Hill Descent Control – Black
(RH) 9L3Z-17682-BB - $114.96
(LH) 9L3Z-17683-BB - $113.75
Power, With Hill Descent Control – “Paint to Match”
(RH) AL3Z-17682-HAPTM - $133.80
(LH) AL3Z-17683-HAPTM - $132.87
Power, Heated – Black
(RH) 9L3Z-17682-CB - $142.65
(LH) 9L3Z-17683-CB - $251.58
Power, Heated – “Paint to Match”
(RH) 9L3Z-17682-DBPTM - $181.10
(LH) 9L3Z-17683-DBPTM - $289.37
Power, Heated – Chrome
(RH) 9L3Z-17682-GA - $185.99
(LH) 9L3Z-17683-GA - $294.25
Power, Heated, Puddle Lamp & Power Fold
(RH) 9L3Z-17682-EB - $301.43
(LH) 9L3Z-17683-EB - $420.67
2005 Wiring Diagram
2007 Wiring Diagram
I hope this helps you guys out.
thanks guys!
**2004-2006
Manual
Power
Manual
Manual
Power
2005 Wiring Diagram
2007 Wiring Diagram
And I just got a reply from Matt:
Reply Sent: NEW!
Date: Monday, October 18 2010 02:37 PM
David it appears that this is a differnt mirror in the end it does not have the big top mirror and the little mirror on the bottom like all of the tow mirrors.i have not sold any of these kits . if you were to purchase two new tow mirrors you are still going to save money and have a new mirror instead of converting your mirrors currently.
Matt
So that basically clears up that issue.
David
Reply Sent: NEW!
Matt
David
There are none w/ just power & telescoping. The best option is the Power, Heat, Signal & Puddle Lamp. They are listed below. Remember all mirrors from 2004-2010 are interchangeable. You just might have to do a little wiring but I also included the wiring diagram here in this thread. If any of you guys want to order a set, drop me an e-mail to jlaliberte@tasca.com
thanks,
thanks,
Thanks, I found a 42 page thread about the wiring changes needed. I just need to move pin 8 to the new 9 position and everything but puddle lamps will work, if I have wiring included for turn signals, which it seems some trucks do not.
What year is your truck? It really depends on the year of the truck to determine what you have to change.
I have a 2007, and I ended up not having to switch anything. I didn't even need to run a wire for the puddle lamps. I just bolted it up and plugged it in and everything worked.
Here is a video showing how to install the tow mirrors. I hope this helps some of you guys out.
http://www.youtube.com/watch?v=NvbjIk6xEsE
thanks,
Joshua
thanks,
Joshua
Heated mirror help.
I know that this is a bit of an old thread, but I have to ask. Does any body know if I need a relay to make the mirror heat work. I installed a set of the telescoping tow mirrors on my 07 that have the heat option. The truck originally did not have heated mirrors but the correct wire color is there on both plugs for the heat. If I get the correct control that has the third button for the heat, is there a relay that I will also have to install to make it work?
Thanks in advance for the help.
06 F150 Supercab XLT Telescoping Tow Mirrors
I installed mine with just the power mirrors working for now. On a nice worm dry day I will install the wires needed for the heat ( by then I will not need it ), turn signal and puddle light. I went to the junk yard ( my Son did really ) and picked up a few pig tails for the missing pins needed. Only paid a few bucks for them there. Here is what they look like on my truck.
http://s281.photobucket.com/albums/kk232/eagle-751/
