Whelen Strobe kit
Old Feb 22, 2010 | 01:34 PM
Pockets's Avatar
Originally Posted by dsq3973
I ran the cables along the inside of the frame rail and through the vent on the back of the cab.
Cool cool good idea im assuming your box is under your rear seats
Old Feb 22, 2010 | 01:44 PM
dsq3973's Avatar
The box is Velcroed in my center console because I only had 15ft of cable to get to the front of the truck and the right side was really tight getting it there. I only have three inches of slack on the right side
Old Feb 28, 2010 | 02:44 PM
Hahny13's Avatar
I have a 98 and 00 both have hide hideaways in them. I used to work for an upfitting company and we did many emergency vehicles. I have a 90watt 6 pack in my 98 now and have two in the rear reverse lights and had two in my aftermarket projector headlight housings (which i hated but the strobes looked great). If you have a long bed like I do, you will need 30 ft cables for atleast one side depending on where you mount your box. I have mine mounted to the rear cab wall. 15ft for the fronts are fine. There is a limited amount of space in the factory taillights and you have to drill the 1in hole just right to get it to fit, but it will work just fine. A strobe in a factor tail light looks really good very bright and draws alot of attention. If you opt or have aftermarket tailights they will look even beter. If you have anymore questions about the process i can go more into detail.
Old Mar 31, 2010 | 03:45 PM
bboyer1969's Avatar
Here is where I mounted mine.
http://www.youtube.com/watch?v=KK4-UF74A_s
