anzo headlights fogging
Old Aug 2, 2009 | 10:32 PM
rlandry2010's Avatar
ok not sure if im in the right place for this but...i got a pair of the anzo projector headlights i love the look but they lack some brightness i find....anyways one of the lights tends to fog up alot and form like condensation on the inside any ideas how to stop this or should i contact anzo and see about it? an also anyone kno if you can adjust the direction the lights shinch they seem to shine off to the side and high
Old Aug 2, 2009 | 11:35 PM
Old Dogg™'s Avatar
Not sure which lights you are talking about but....
If you haven't already you need to seal them around the seams with clear silicone. The water soluble silicone in the tube is the easiest. Non water soluble last longer.
The F-150 Anzo lights have a allen head silver screw adjustment on top over the projector that adjust up and down illumination.
Old Aug 3, 2009 | 10:05 AM
thanks i thought about sealing them wen i installed them but it did not say it in the instructions so i was hesitant about doing it
Old Aug 3, 2009 | 11:07 AM
Old Dogg™'s Avatar
All (and I have had many) aftermarket lights tend to leak or have some sort of water intrusion problem.
With LED circuitry a little moisture goes a long way to causing problems so it's always better to be safe than sorry.
Good luck!
Old Aug 3, 2009 | 01:24 PM
any ideas on how to get rid of the water thats left in there out?
Old Aug 3, 2009 | 02:16 PM
blackf150337's Avatar
blow dryer, or if you have some packets of those things that absorb moisture tie some to a string and drop them in overnight and pull them out.
Old Aug 3, 2009 | 02:28 PM
good idea
Old Aug 3, 2009 | 02:52 PM
rednoved's Avatar
Tampons?
Old Aug 3, 2009 | 04:50 PM
Originally Posted by rednoved
Tampons?
that would prolly do the trick.....but ill pass
