just installed...
Old Jul 8, 2009 | 10:28 AM
thenewfx2's Avatar
just installed...
yo i just installed the hella 500 behind my fx2 grill was actually a very easy mod i will be posting up pictures later on today cuz the truck is at the muffler shop getting another exaust pipe out of the other real end pics will be up soon
Old Jul 8, 2009 | 12:56 PM
KR-Texas's Avatar
Need pics soon...
Old Jul 8, 2009 | 01:10 PM
thenewfx2's Avatar
i get out of work at 5 i will have pics up i found the perfect bracket for it just spray painted it and mounted them i was done in about 30 mins longest part was waiting for the bracket to dry and they ar behind an fx2 grill hey but once i get the pics how do i post them on this thread?
Old Jul 8, 2009 | 01:19 PM
drew622's Avatar
yes...need pics & details
Old Jul 8, 2009 | 01:22 PM
thenewfx2's Avatar
ok put how do i post the pics on this thread
Old Jul 8, 2009 | 06:17 PM
KR-Texas's Avatar
Click on your username in the upper right hand side of the main screen and create an album in your profile section
Upload the pics into your album and then grab the BB Code from the bottom of the picture and paste it into your message. If you use the URL code, you will have to paste it in with the "insert picture" icon above the area where you add text into messages. (The icon looks like a mountain with a sun)
I always "preview" the post to make sure it is the right picture and it is going to display correctly, before submitting it.
KR-Texas
Old Jul 8, 2009 | 06:47 PM
gatorbait10's Avatar
and give some info about the perfect bracket you found...
Old Jul 8, 2009 | 10:47 PM
thenewfx2's Avatar
Will post more tomorrow. Sun came down on me.
Original Grill with no Fogs
Hella 500 Fog lights installed behind Stock Grill.
Fog Lights are mounted on a Drilled L shaped Bar which can be found at Home Depot. Holes are already drilled. May have to be cut an inch or so.
Both ends of Drilled L shape bar will be held in place by the stock inner screw that holds the headlights in place.
Width of the bar is a perfect fit. Just like i posted above you may have to cut the L shaped bar. Not difficult at all.
Close up on how Bar should be mounted with screw. (Right headlight)
Close up on how Bar should be mounted with screw. (Left Headlight)
L shaped bar comes in silver but i purchased Flat black spray paint and painted bar. If anything this is what takes up the most time. Last but not least. The lights can be mounted to your preference with holes that are already drilled in L shaped bar.
Old Jul 8, 2009 | 10:48 PM
thenewfx2's Avatar
Any Questions, feel free to ask. Thanks
Old Jul 9, 2009 | 02:04 AM
thenewfx2's Avatar
pics are up pics r up
Old Jul 9, 2009 | 09:03 AM
BigNate's Avatar
Very nice. I want to do this mod as well.
Old Jul 9, 2009 | 10:20 AM
thenewfx2's Avatar
u should man it is a very inexpensive mod and makes ur truck look really different u will spend about 55 dollars buying all the materials u need and installing is easy
Old Jul 9, 2009 | 02:14 PM
drew622's Avatar
Looks great!!! Are the lights are pretty stable? Not any shaking?
Old Jul 9, 2009 | 03:25 PM
animated_zombie's Avatar
I've been wanting to do the fogs behind the grille as well. I like the idea of using a L Bracket. I've been trying to think about how to fab something up with my limited skill, and this seems like a good way to go about it.
Good Job!
Old Jul 9, 2009 | 06:33 PM
thenewfx2's Avatar
the lights are very stable on the l bracket the only thing is the l bracket moves a bit but only when u push on it or move it because it doesnt have a base in the middle just at both edges of the bracket but its not going anywhere at all
