Map and dome light Led's
Old May 15, 2009 | 12:30 AM
LoneRanger93's Avatar
Originally Posted by ibcop
If you switch out the tails and third brake to LED's (I had the Hella's in my 06 KR), you only have to replace the factory brake light fuse with the supplied one (at least in my case). I had to install a 7.5 amp versus the factory 20 amp.
I didn't have any issues with the cruise.
Do you have any more info regarding that? You put swapped in a fuse rated for lower amps? and this fixed your cruise control issue?
Old May 15, 2009 | 12:42 AM
alomar's Avatar
I ordered these for my license plate:
http://www.v-leds.com/Exterior-LED/C...81133-1-2.html
But they were too long! They would go into the socket, but they were a hair too long - the socket didn't have enough clearance to turn back into position. Another thing I found - it seems the light housing is curved enough so if you use a standard 194 LED bulb (with the LED at the end of the bulb) so you don't get the true light output through the lens. It appears you need a LED bulb with the LED's around the bulb and at the end. Problem is, I can't find any "shorties".
Anyone had any success?
http://www.v-leds.com/Interior-LED/D...68086-1-2.html
Old May 15, 2009 | 11:32 PM
kuruption's Avatar
I had white LEDs in the dome/map lights, but a friend with a red Mazda3 turned me onto the idea of putting red LEDs instead. They aren't quite as "bright" as white LEDs (maybe half as bright), but give the truck a cool look, and red does not require your pupils to adjust, so easy to drive at night with them on.
Old May 17, 2009 | 09:03 AM
jasondell's Avatar
LEDs are great! I was told they last for about 15 years. I bought some rope-type lights from a marine lighting supplier, which you can buy by the foot, they look great. LEDs is the way to go for any lighting.
Old May 26, 2009 | 09:10 PM
RebelOne's Avatar
How do you take the covers off the interior lights? I was trying to figure it out for an hour and gave up.
Old May 26, 2009 | 09:18 PM
johnnyd2723's Avatar
They pop off with no tools. I just did my father-in-laws a few weeks ago and the rear one was a pain to get off but it finally popped off. It feels like they're going to break but just keep pulling, they'll come off.
Old May 26, 2009 | 10:03 PM
WhiteRoush3's Avatar
Does anyone have an exact part number of the license plate leds they are running with no problems? and the site you grabed them from?
Old May 26, 2009 | 10:12 PM
Here ya go
http://www.v-leds.com/Exterior-LED/C...-p4481133.html
Old May 26, 2009 | 10:53 PM
Originally Posted by johnnyd2723
do you have them on your truck, because i saw anoter post here where a guy said he had problems with those not fitting? thanks
Old May 26, 2009 | 11:00 PM
alomar's Avatar
Those will fit, they are short. I had some longer ones that did not fit, gotta make sure you order leds that are as short as possible. otherwise it will hit the light housing.
Old May 26, 2009 | 11:09 PM
Yes I do and they work just fine. I thought they didn't fit at first too but I didn't have the twist in socket lined up correctly. It felt like the bulb was to big.
I then bought these ( http://www.superbrightleds.com/specs/bulb_specsHP.htm ) for my Father-in-laws truck and they work fine too.
Read this thread. I believe pg 4 or 5 discusses lic. plate bulbs: https://www.f150online.com/forums/20...uestion-5.html
Old May 26, 2009 | 11:40 PM
jrfonte's Avatar
whats everyone using in there map and dome for leds im just curious.
i have 5 superbright 3mm white and 2 superflux 4 chip leds in each map and 2 superflux 4 chip leds and 24 3mm superbright white leds in the dome. and there pretty bright at 12.5v when the engine is off and really bright when its running at 14.4v.
heres a pic at 12.5v with no flash on the camera at night.
