Painting chrome handle covers??
Old Mar 25, 2009 | 07:46 PM
RiverRacerX's Avatar
Instead of buying LT handles or sanding down the textured black door handles, has anyone bought the chromed plastic handle covers and sanded them down and painted them??
I know painting over chrome sukz azz, but I think if you prepped it right it might work OK?
Just thought it would be easy to prep and paint off the truck, then just 3M over the black OEM?
Thoughts?
Old Mar 25, 2009 | 08:08 PM
04PJ's Avatar
I would just try to scuff and paint them.
Just seen they were plastic, yeah I would just scuff them, a couple coats of adhesion promoter, then whatever you color coat is followed by clear.
Old Mar 25, 2009 | 11:51 PM
jjntj2003's Avatar
that's what i did also did the half mirror covers
https://www.f150online.com/forums/me...icoftruck3.jpg
Old Mar 26, 2009 | 03:26 AM
smrcalidiv's Avatar
I would also like to see someone do this...I have been thinking about it for sometime now.
Old Mar 26, 2009 | 03:15 PM
brendanlush's Avatar
I will be attempting to do my stock black door handles and the tops of my mirrors when it warms up. I am curious to see what it will come out like.
Old Mar 26, 2009 | 04:37 PM
I did my fenders and mirror caps with DupliColor, but I want to re-do the mirrors with the automotivetouchup.com paint. Mirrors were easy!
Old Mar 26, 2009 | 05:50 PM
IDNC76's Avatar
i would love Ptm handles and mirror caps but dont wanna spend the $$ nor the time fiddling taking everything off.
i too was always curious how well the chrome covers hold up painted , and also if you can actually tell if there is a cover on the handle ?
Old Mar 26, 2009 | 05:53 PM
IDNC76's Avatar
are these actually the chrome covers or Lt handles ?
looks good
Old Mar 26, 2009 | 06:06 PM
Taking the fenders off wasn't hard but took time for the whole deal. The mirror caps are cake. You could have them off and painted in under an hour.
Old Mar 27, 2009 | 01:46 AM
Any tips on how to take the mirrors apart like that? It seems so much easier than taking the mirror completely off!
Old Mar 27, 2009 | 11:03 AM
GB Black Lariat's Avatar
I painted those same exact handle covers. Scuff them up with 400 grit, spray adhesion promoter then base and clear
Also did the mirrors the same way but used high build primer to get rid of the texture
Old Mar 27, 2009 | 12:13 PM
I used a high build primer as well. My stuff came out nice and smooth. See my fender thread.
The mirrors are easy:
Push the bottom of the mirror all the way down and look inside to see where the mirror is attached to the motor.
Take a long thin screwdriver and pry the little plastic tab off, the mirror should pop off the motor very easily.
Now there are 4 torx screws golding the front of the mirror on. Remove the screws, you now have the entire front of the mirror shell ready to come off. Pop it off and you are good to go.
Mask, sand, paint and reassemble. It was WAY easier than I thought it would be!
Old Mar 27, 2009 | 01:37 PM
DaHangLow's Avatar
I painted some SS fender flares. Scuff, etching primer, adhesion promoter, paint, color sand then clear. Came out great. Just my 0.02.
Old Mar 27, 2009 | 02:38 PM
jjntj2003's Avatar
looks good
those are the ebay covers, left pull part chrome painted the covers and half mirrors. i sanded aand used adhesion promotor. ordered paint from www.automotivetouchup.com it held up well just redoing because with 4yr old red paint didn't match close enough. if you look close enough you can tell they are the covers.
Old Mar 27, 2009 | 02:44 PM
HighOn22's's Avatar
I'm not sure what body shops in your area are charging, but it only cost me $300 to get all my stuff done. I dropped the truck off and they took everything apart then put it back together in 3 days.
