Gauge Cluster questions
Old Mar 10, 2009 | 08:47 AM
spoiled's Avatar
I have a SuperCrew with stock cluster. Can I change my cluster with on with a tach like the Lariat or other models?
Is there plugs for the tach behind the stock cluster? Does the odo show what the truck actually are on teh stock cluster?
thanks for the noob questions, I am slowly learning as this is my first truck and love it.
Old Mar 10, 2009 | 10:16 AM
bjp207's Avatar
you can change it, the new one has to be from the same year, and has to have the same or more miles so that you can swap them at the same mileage...The mileage WILL NOT transfer onto a new cluster...it stays with it. You will have to get the dealer to reflash the PCM to get the tach to work. I did it on mine, works wonderfully
Old Mar 10, 2009 | 09:00 PM
grassmanfx4's Avatar
Hey spoiled i wanna change my stock fx4 gauges to white lariat gauges too.Let me know how your search goes.
Old Mar 10, 2009 | 09:57 PM
spoiled's Avatar
I will let you know what I find out.
Old Mar 11, 2009 | 01:35 AM
GreenBuck50's Avatar
What year truck do you have? Is it an 01-03, 04-08, or 09?
Old Mar 11, 2009 | 05:16 AM
spoiled's Avatar
Its an 08
Old Mar 11, 2009 | 09:22 AM
Raptor05121's Avatar
Yeah, the tech guys at the stealership are going to have to flash the PCM. And if you can find a cluster in good shape, your looking to spend a Ben Franklin here...
Luckily with the 97-98 year, I was able to swap mine out 'cause I dont have a PATS
But I will agree, a tach is most definitely helpful and fun to have.
Old Apr 5, 2009 | 02:51 AM
turyf150's Avatar
Hi Everyone.
I have a 1998 F150 XLT, I will set up a glow gauge kit, do I have to take out the full cluster to set it up? any guide on how to remove it would be great
Thank you.
Old Apr 5, 2009 | 05:36 AM
pop off the HVAC, remove screws there (i think all are either 5mm or 7mm) then pop off the thing that surrounds the sterring wheel, remove those, the 3 above the cluster, one is by your left knee by the fuse panel, and another is around there accessed by pulling the panel off. you also have to remove the headlight controls.
Old Apr 5, 2009 | 02:50 PM
turyf150's Avatar
Thumbs up
Thank you, I'll let you know how it went.
Old Apr 7, 2009 | 09:52 PM
turyf150's Avatar
My gauges just arrive on today’s mail; I will set it up tomorrow and let you know how it works out.
Old Apr 7, 2009 | 10:00 PM
dane25's Avatar
I think you can change it....
Old Apr 10, 2009 | 04:43 PM
turyf150's Avatar
Already finish
Cluster out
Reassembling the cluster after setting the new gauge
Light on but at day time, I have to wait till night to c how it looks
Light off
Update : this is how it looks almost at night , looks great
Old Apr 11, 2009 | 09:02 PM
that whole thing lights up!??!?!
Old Apr 12, 2009 | 07:08 PM
turyf150's Avatar
Yes it does
