HELP! HID kit or new bulbs
Old Jan 25, 2009 | 03:35 PM
f150offroader's Avatar
I was thinking about getting new headlights for my truck. I just wanted to get new xenon or halogen bulbs and but them into my stock headlights. Is this possible, or do I have to get an HID kit with ballasts and everything else? Any help will do? Thanks.
Old Jan 27, 2009 | 04:34 PM
XenonLink's Avatar
Smile
If you are searching for brighter lights than your stocks then HID conversion kit will be it.
6K or 8K are the most common used.
6K - Majority white with light blue
8K - More blue with a hint of white
Refer to the below link for examples.
http://www.xenonlink.com/product_inf...roducts_id=107
I would be able to offer you some discounts if you order directly through me. My contact is 866-857-0005 ask for William.
Old Jan 27, 2009 | 04:41 PM
05_sprcrw's Avatar
You can get new bulbs and be fine but you will not get much more light out put. IF you are going for brighter then HID conversion will be the way to go. If you want to retain your high beams then you will want to order a bi xenon kit. William has told you about the colors so I will skip that. But honestly if you are thinking about using Silverstar Ultras then you are looking at roughly $80 for fogs and heads. Depending on where you buy and the options you want, you can get two kits from $100-$200. I would do the headlights with HID's and then save for the fogs.
I personally would not go back to running regular headlamps ever again. I am working on getting a set of HID's for my girl friends car now as well. The amount of light out put is night and day difference. Plus they look a million times cooler One last thing either way make sure you re aim the head lamps so you don't blind other drivers.
Old Jan 27, 2009 | 06:25 PM
Ok great thanks.
