What bulbs do I get?
Old Dec 23, 2008 | 11:33 PM
Westcoast4121's Avatar
Question What bulbs do I get?
I don't know what bulbs to get? I got new headlights and want to put bright bulbs in it but don't know which bulbs to get. I want them bright Thanks
Old Dec 24, 2008 | 03:50 AM
MmmBuckles's Avatar
9007 silver stars
Old Dec 24, 2008 | 05:54 AM
Fifty150's Avatar
Hella Performance Headlamps
H13/9008 Xenon Blue replacement bulbs
60/55 watts, SAE/DOT approved
Features
Overview: Hella's high performance blue bulbs produce a brighter, whiter light that is closer in color temperature to actual daylight. This provides increased visibility and less eye fatigue for the driver in all conditions.
D.O.T Compliant: These Xenon blue bulbs are D.O.T compliant and street legal.
Blue Bulbs: The blue coating on the bulb produces a crisp white beam when turned on.
Alignment: Correct filament alignment assures maximum light output when installed.
Compatibility: Please consult the Crutchfield Vehicle Selector to see if these replacement bulbs are compatible with your vehicle.
Installation: Refer to your vehicle's owner's manual for information regarding bulb replacement.
Caution: Do not touch the glass bulb. The fingerprint you leave behind may cause damage to the bulb as it gets hot.
Specifications:
* Voltage: 12V
* Wattage: 60/55 watts
Old Dec 24, 2008 | 12:17 PM
4wd150's Avatar
ill be putting my philips crystalvision ultras in soon. supposedly they will look good
Old Dec 24, 2008 | 03:22 PM
Raptor05121's Avatar
Nothing will beat the light output of High Intensity Discharge lighting from a Xenon bulb.
