Lightning headlight question
Old Oct 16, 2008 | 07:33 PM
4wd150's Avatar
im looking at these on lmc truck http://www.lmctruck.com/ICATALOG/FE/full.aspx?Page=100
what do i need to order beside each side headlamps and corner lamps? do i need any of the wiring or is it just an even swap from my sotkcer headlight assembly? if anybody can help m out that would be great! thanks!
Old Oct 16, 2008 | 09:10 PM
Raptor05121's Avatar
All you need is the two headlamps and turn signals. You use your existing bulbs. If you still have stock bulbs, I insist on you upgrading to Sylvania Silverstar 9007's for a brighter output. Or, you can do what we did and get HIDs. I must let you know NOT to order form LMC truck if you like money. They are hella expensive. Look around, you can get all four pieces for about $150 total. Google is a great place to start, as it importvision.com. Happy hunting!
Old Oct 16, 2008 | 09:26 PM
4wd150's Avatar
haha thanks man! found these for 159!!! http://images.andale.com/f2/115/106/...03PHCC_COM.jpg
so just purchase some new bulbs at auto store and ill be good to go? i read something on here about Stealth bulbs for turn signals that they arent amber when not in use or do i need regular amber bulbs for lightning headlights?
Old Oct 16, 2008 | 10:07 PM
dirtyd88's Avatar
you know that those depo projectors require a third bulbs, right??
importvisions had reproduction L headlights...just do some searching....also check out nloc.org and nhtoc.com!
Whitening98's Avatar
you can get stealth bulbs, they are chrome to match the headlight, i have em on my truck and it looks alot better than having the egg yoke color on your truck!
Old Oct 16, 2008 | 10:21 PM
If you go from stock to true Lightning headlights, like i did, you will need to buy the ring that holds the headlight bulb down. I got mine from the dealership for right at 20 bucks. But call ahead b.c they usually have to order them
Dont settle for anything other then Visteon Lightning headlights
I got mine off of a 2001 lightning, they were on ebay for 125 shipped, and i paid 40 shipped for the parking lights from a different guy
Old Oct 18, 2008 | 03:32 PM
4wd150's Avatar
alright thanks for all the info guys! but is there anything wrong from ordering them off of importvision? then i would need some sort of ring i can get at the deal you said? and what about a 3rd bulb? i was planning on getting silverstar ultras for headlights and ordering the stealth bulbs. what else do i need? thanks
anybody know the number silverstar ultras i would need?
