Any pics of '97-'03 with light behind the grille?
Old Aug 17, 2008 | 10:32 PM
EC99SS's Avatar
I recently saw a pic of a red '01 with lights positioned behind the grille. I thought it look great both in the daytime and at night. I was curious if there's a kit for that or if it's a custom job. Does anyone have any input and/or pics I can see?
Old Aug 18, 2008 | 04:14 AM
joshmac4.6's Avatar
Like this??
I just drilled the backside of the grille, and ran bolts through the bottom, I have not seen a kit for this setup, however LMC Truck sells a kit for the 99-03's that is a billet grille insert that has the holes already in it to mount the lights in the grille, not behind.
Old Aug 18, 2008 | 06:30 AM
Veteran: Army
built54 has a similar setup on his big bad blue beast
Old Aug 18, 2008 | 11:14 AM
EC99SS's Avatar
Cool thanks all
Josh...thanks for the pics!
Old Aug 19, 2008 | 07:13 PM
Raptor05121's Avatar
My dual Hella 2020 Driving/Fog Light combo. I use them for DRL's mainly, and when at night I only use my mains because HIDs and halogens look like crap together. But since I do not have high-beams, I have upgraded these quite a bit. Stripped the 20 gauge wiring out that came stock, replaced it all with 12 gauge. Added a fuse coming off of the two relays. Installed TWO ground posts on a 13mm frame mount for each side. Pulled the little stock 55W bulbs and replaced with 100W Sylvania H3-ST bulbs (4000K) and aimed them UP so if I ever get flashed, these bad boys will burn some retnas! I'd LIKE to get H3C HIDs for them, but $160 for such tiny little bulbs is a kinda waste of money.
^^^ Lights off \/ \/ \/
\/ \/ \/ Driving beams \/ \/ \/
\/ \/ \/ Fog lights and HIDs \/ \/ \/
Old Aug 19, 2008 | 07:15 PM
^^^ passenger side ^^^
^^^ drivers side 6000K HIDs ^^^
^^^ Full burners ^^^
