Bullbar mounting brackets
Old Dec 10, 2007 | 12:33 PM
ArmyGuy's Avatar
Does anyone know where to get the brackets to mount a bull bar? I intelligently left the mounting brackets on my '05 when I traded it for an '07. They seem like they would be fairly easy to fabricate, if a guy knew how to work with steel (I don't). I'm checking ebay to see if any of the sellers offer just the brackets. It seems like it's just a piece of angle iron with four holes in them that match up with where the tow hooks come off. Any help is appreciated.
Old Dec 10, 2007 | 06:27 PM
K1NGoftheRanch's Avatar
what bull bar do you have? you may be able to contact the company directly...
Old Dec 10, 2007 | 09:48 PM
ArmyGuy's Avatar
I actually was able to fabricate some out of angle iron from Lowes. I should have made them about 1/2 inch longer as they are touching the plastic of the bumper, but it's nothing that's going to leave a mark or damage anything. I was kind of proud of myself. I just took the tow rings off and used them as the template for the mounting holes on the truck and then used a piece of thin plywood to make a template of the holes on the bull bar. I drilled the holes, cut it to length (about 1/2 inch too short i found) and mounted it and it looks great. I wired up my fog lights and it's all set. I did contact Westin and they gave me the part number, but when I called NAPA and Oreilly's (Westing gave me those suppliers specifically) they could not locate the part number.
Old Dec 10, 2007 | 10:00 PM
attworth's Avatar
Make sure you made the brackets strong enough. You don't wanna have that falling off, or crushing your bumper and everything behind it in the event of a wreck.
Old Dec 11, 2007 | 08:53 AM
ArmyGuy's Avatar
The steel I used is thicker than the original brackets so I think it's good. I tugged on it repeatedly just because I often doubt my own ability, but it seems like i could just about tow a vehicle with it (not that I would). Again, my main mistake was the length. I might make a couple more that would be a little longer to make the bull bar sit about a 1/2 inch further forward. Even after I saved about $40 by making my own brackets, the wife said "Why don't you just go see if your truck is still at the dealership?" It's been about three months and it's a big dealership that I pass every day, but she can't resist a jab instead of an attaboy.
