Box Lights
Old Dec 2, 2007 | 03:53 PM
mark03screw's Avatar
Box Lights
Heres a mod i did so i can actually see whats in my box at night.
I installed two box lights (one on each side) in the back of my box. I attached them to the corner pillers because they provide a perfect channel for the wiring. Plus they work good there and are out of the way.
I drilled an either 3/8" or 1/2" hole for the wire loom (which popped through anyways) and ran the wires down the column.
Old Dec 2, 2007 | 03:54 PM
I simply screwed the ground wire to the box when i attached the light to the frame. Use 1/2" self-tapping screws.
I then ran both wires to the hitch and tucked them up as far as i could and zip-tied them to existing wires.
Then i wired them to the 4-pin plug (easier access than the 7pin) and to the running lights wire (the brown one).
It was -20C when i did do it, so i did a bad job wiring it to the 4pin, but it works. The crappy part is i have to start my engine in order for them to work. It is good however because i always forget to switch them off, so now it can't drain my battery.
I'm gonna wire them to my cab and put a switch in this week when i install my reverse backup lights, so i can use them without starting my truck, but i wont forget to turn them off cause the switch is in the cab.
The end result.
Old Dec 2, 2007 | 06:18 PM
gixxerjasen's Avatar
That's awesome. I have a tonneau cover that doesn't lift at all. I might end up with something like that if I don't just get rid of the cover altogether.
Old Dec 2, 2007 | 07:33 PM
ATOM's Avatar
good idea, i gotta do something like that soon, its impossible to see in the back of the screw when the tonneau is down and holding a flashilght is too much work you could always add some super white bulbs or leds to make it even brighter too.
Old Dec 3, 2007 | 09:18 AM
jk007's Avatar
Mark,
Thanks for the post buddy. I will definately be doing this mod. It looks very clean and you did a great job. I appreciate you posting the pics and the step by step. Nice work...
