Removing Badging
Old May 27, 2007 | 04:53 PM
bonder45's Avatar
Removing Badging
I try to find another thread like it but I couldn't.
So I want to remove the rear F-150 and Side F-150 badging....
Is it just a basic sticky or will there be holes left on the side of the truck
(when I removed them off a 2005 F-350 It left holes in the side and I dont want that )
I have a 06 F-150
Old May 27, 2007 | 05:26 PM
ziggaboo's Avatar
2 holes behind each with sticky holding em on.
Old May 27, 2007 | 08:56 PM
bonder45's Avatar
Is that with the back too or just the sides?
Old May 27, 2007 | 10:18 PM
04gtf150's Avatar
All three badges have the two locating pins
Old May 27, 2007 | 11:26 PM
bonder45's Avatar
Grr.. that ****'s a guy off...
I wonder what it would cost to get filled and repainted
Old May 28, 2007 | 12:21 AM
flareside4life's Avatar
Do it no matter the cost, WTF was Ford thinking putting the F150 badge on the middle of the tailgate? Sorry just ranting, get a little bro that does body work, free labor, only cost is paint.
Old May 28, 2007 | 02:05 PM
Arca_ex's Avatar
Yeah, that's what I was thinking about the badge. Plus on the newer ones, it is GIGANTIC! Nearly 6 inches accross!
Old May 28, 2007 | 02:29 PM
DTheobald's Avatar
does a 05 tailgate badge w/o the raised lettering fit an 07 model year tailgate? I want to switch out my bro's badge with mine cause I want to put an emblem overlay on it...??? will it have the same holes?
Old May 28, 2007 | 05:12 PM
dubbass33's Avatar
i just took off my F150 emblem on my tailgate. ended up filling the holes with bondo. now i just gotta paint it
Old May 28, 2007 | 08:24 PM
Don't slam that tailgate too hard...
Or else I'm gonna be ROTFLMAO, while you have 3 holes in your gate again, speed is no subsitute for the proper techniques, and Bondo is not a fix all substance.
Old May 28, 2007 | 08:26 PM
Yes, they should be the same, but you will need some new double sided foam tape to reattach it.
Old May 28, 2007 | 08:36 PM
dubbass33's Avatar
i know, but it works. 4 coats on it
Old May 28, 2007 | 09:52 PM
Until it pops out after going over a pothole.
Old May 28, 2007 | 11:43 PM
NHSP-06's Avatar
the correct way to do that would be to make a metal plate and have it welded in place of the Ford emblem and then use bondo to simply "touch up" and blend. Bondo itself will simply fall right out of that indent if that is all you plan on putting there.
