Best looking bug shield
Old Nov 12, 2006 | 11:23 AM
45/70sharpshoot's Avatar
I have done a search with Way too many results. So... which is the best looking /best fitting bug shield for a 06 screw??????? Thanks,45/70
Old Nov 12, 2006 | 11:48 AM
BalogUK's Avatar
the ford low profile... which is mfr'd by lund i think.
Old Nov 12, 2006 | 02:39 PM
green06F150's Avatar
Registered User
I too, got the low profile shield from FoMoCo....has the F150 script above the driver's side head light.....fits great...no vibration...nice spacing...
Old Nov 12, 2006 | 03:01 PM
FoMoCoFan17's Avatar
I have LUND lo-pro. Looks great and I think it is a little thicker than most others.
Old Nov 13, 2006 | 08:42 AM
statgator's Avatar
I bought the Ford bug shield and I think the instillation is not ideal. It has clips that clip onto the hood and I feel after a long while will damage the paint. Just my .02.
Tom
Old Nov 13, 2006 | 08:01 PM
ian51279's Avatar
x2.
Old Nov 13, 2006 | 08:17 PM
RUSS04's Avatar
Ihad the full wrap bug shield from ford But i didnt like the clips on the edge of the hood I bought the plastic chrome one from ford that fits behind the grill with no clips It does not wrap around the hood Pics in my gallery I hope this helps you out
Old Nov 13, 2006 | 11:56 PM
ws6_guyscrew's Avatar
I like the low profiles, any stock one looks best.
Old Nov 14, 2006 | 10:21 PM
bugsheild
Thanks to everyone . How would you rate how your bugsheild attaches to your truck. 45/70
Old Nov 15, 2006 | 08:18 PM
ian51279's Avatar
On mine the grille had to be removed. I think it's 10 bolts. It's sandwiched between the edge of the hood and the grille.
Old Nov 16, 2006 | 10:45 AM
98UltraZ's Avatar
I have the ford low profile deflector. There is a thicker plastic "sticker" that you put on close to each corner of the hood. Then there is a metal clip that you slide onto each of the stickers in order to keep from them being put directly on the paint. The center of the deflector is between the grill and the hood. I liked how my GM bug deflector attached to the hood of my 2500HD a lot more. Obviously the front ends are different on the F-150, so there is not a lot of options for attaching them. I think it has saved a ton of rock chips though. Another item I have used in the past and really liked was the 3M stone guard protector. It is a clear film they put on the paint to keep it from getting chipped. I had it on my 01' Camaro SS, I took the film off the car when it had 21k miles on the car. There was not one chip on the front end. It looked the same as the day it came off the showroom floor.
Old Nov 16, 2006 | 11:47 AM
adfox77's Avatar
I have the Ford mini-chrome deflector
I like how it mounts. You have to remove the grill and use the bolts on it to mount the deflector. It goes on between the hood and the grill
