Projector Headlights
Old Nov 8, 2006 | 06:39 PM
2000F150's Avatar
Originally Posted by LUKE_DUKE
I had some xeon bulbs in my projector head lights and within about 8-10 months, it melted my wiring harnesses for both sides... not fun. Had to splice in a new harness. Be carefull...
I read about that somewhere so I went ahead and bought the high wattage wiring harnesses.
Old Nov 8, 2006 | 09:10 PM
DIYMechanic's Avatar
Thumbs up
Originally Posted by adt
Those are very simular to what I have on my 01 SCAB. The instructions did say that HIDs will not work in them. I assume because of the heat.
ADT, sweet looking headlights. I've been looking at those exact same ones for my '99 SCAB. How do you like them? Any trouble installing them? Do the other three LED's on the bottom come on at all? TIA--DIY.
Old Nov 9, 2006 | 05:53 PM
adt's Avatar
adt
Thanks I like them to but I'm not reccomending this particular type. The projector lamp is useless. There's a flat line across the top when I shine them on my garage door. The regular low beam light is very bright though. The 3 LEDs on the bottom are dummies, only the first three come on like you see in the picture, but I still like the look. The halos are trick, I love the look. Install was easy, just use wire taps to connect the halos/LEDs to the parking lights. Hardest part was aiming them right. Good luck.
Old Nov 10, 2006 | 07:03 AM
Sweet, thanks for the info. I'll steer clear of that particular type.--DIY
