got my westin's help!!!!
just to save me another headache like the one I just got trying to find where to bolt on the face plates .. can someone help me out?
I can't figure out where the hell the bolts go through.. I found the rubber pieces on the body, they come off easy, but how the heck do you get the bolt through the body?? There's no holes going through ther whole thing!!
any help would be apreciated
97 F150 XLT: Two-Tone Green and Tan,V6 4.2L auto 4X4, 3.55 gears, 265/75/16 Dueler AT's
MODS:Airaid FIPK, Superchip, Ravin Z55 exhaust SI/SO
GOODIES:12 disk cd changer, jvc 4ch 560watt poweramp, Bazooka tube, Boston Acoustic 5x9's, Tinted Back, Westin Nerf Bars..
Hey patrickjp,
I'm asuming they are the silver colored plates with the threads sticking out?
The trick is to put one of the bolt threads into the hole first,kind of like carrying a table through a doorway. Then just drop the whole plate inside. grab one of the threads and pull the plate up against the rocker panel from the inside with the threads sticking out the hole. The next trick is to put the BAR mounting bracket up onto the threads without it falling back into the rocker box
It takes a little cursing,and finesse,but once you get it it's pretty quick to do the rest. I do feel for you,the instructions bite,huh? Good luck,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's,,too noisy
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Clear front corners
Grillcraft grill insert
Speedglo gauges w/carbon fiber overlay,might paint it black
Stillen Quad light air dam,Sweet!!
Euro taillights w/l.e.d. bulbs
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,and Soundstream P203e amplifier//Single 10" sub
Viper alarm
On the way/wheels,tires, etc..etc.......
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
It takes a little cursing,and finesse,but once you get it it's pretty quick to do the rest. I do feel for you,the instructions bite,huh? Good luck,,,,,98------------------
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Viper alarm
I think I know what you're talkin about. If I'm right take a thin piece of wire and wrap it around one of the studs and use that to hold the plate in place while you bolt the other side into place. when you have the one side held up you can pull the wire out and bolt up the other stud. Easy huh.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
285/75 R16 Kelly Springfield Trailcutter RTs
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
