vent shades
Old Jan 22, 2001 | 06:45 PM
Travis W's Avatar
Post vent shades
I bought some vent shades for my 97 X cab, and noticed that they use double sided tape to attach. I thought some brands just stick up in the weather stripping. I dont want to stick them to the paint, does anyone know if they are all like this for the 97-00 F 150's?
97 supercab flareside 4x4, 5.4, cd changer, captians chairs, bedliner, hard cover, 17 in rims
Old Jan 22, 2001 | 07:04 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post
I have the Ventshade brand that uses doublesided tape and it doesn't touch the paint. Line it up to see if that's true for what you got. There is a rubber or plastic seam around the edge of the door where it is applied. They 'DO' go on the paint in the Chevy application. Just follow the directions and make sure to use the alcohol swab. I have seen these things flapping in the breeze on other trucks. Mine have been on for nearly two years with no problem.
Old Jan 22, 2001 | 08:38 PM
jgorka's Avatar
Post
I had a nice set on my '97 -- however I did not like the fact that they drip water into the window and add quite a bit of blind-spot to the door pillar -- so there's none on the Y2K.
Y2K™ 7700 4x4
Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old Jan 24, 2001 | 05:22 PM
Travis W's Avatar
Thumbs up
Thanks for your replies. I just thought some brands inserted inot the window frame. If it doesn't touch the paint, then no biggie. Thanks also for the heads up about the blind spot. I will hold them up to see if I like em before I install. Thanks again.
Old Jan 24, 2001 | 06:27 PM
hmustang's Avatar
Post
I have profile windstream vent shades and they stick to the rubber weather striping along the out side of the window and a little bit goes onto the the black plastic piece by the side mirrors.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
Old Jan 25, 2001 | 09:51 AM
captainoblivious's Avatar
Post
I have the v-tech oval shades, and they stick on to the window itself with doublesided tape. Only problem is on of the tapes got wore out and now it rattles which is very annoying, so I'll be fixing that shortly.
Old Jan 25, 2001 | 11:01 AM
Raoul's Avatar
25 Year Member
Talking
captainoblivious, now I'm not going to go into this whole 'oblivious' thing, I'm just trying to help here. When you 'fix' it make sure you don't put it on "...the window itself" this time. The shade is not supposed to go up and down when the window is operated.
Old Jan 25, 2001 | 11:40 AM
lariat4wd's Avatar
Post
Yes, I think the "Weather-Tech" ones stick inside the rubber seal.
Check though.
I have Vent Shades Vent Visors on mine. I couldn't get them to stick the the rubber with the double-sided tape, so I stuck them on the paint. That's ok, they'll come off with a little "Goo-Gone"
Good luck.
--Lariat4WD--
2000 Ford F-150 Extended Cab Flareside 4x4 Lariat
5.4L;auto;3.55LS;Black/Silver;ORP;remote keyless;floor-shift 4wd;Class III;AM/FM/SingleCD
Mods so far:
Lund X-Terminator bug shield; Vent Shade Vent Visors; GTS headlight blackouts; Westin Black step bars; Pendaliner bedliner; Genuine Steel Products (Longtek Engineering) black Safari Grille Guard; GTS Tail Blazer II Slotted taillight covers; Clear corner lenses; under hitch backup lights; 2 KC Hilites Daylighter 6" 150W black round off-road lights; Cranked torsion bars to level truck; Removed lower factory striping; Replaced factory gold & maroon ORP decals with silver; 2 Polk Audio EX10 10" subs under rear seat; Sony XM754HX amp; Viper 300ESP alarm
Pending
Replacing factory gold/maroon Lariat decals & upper stripes with silver & black
Wish list:
More lights; Flowmaster 40 Series single to dual exhaust w/ 18" SS tips out back; Optima red top battery; Remote starter & Prox. sensor; In-dash TV/CD/DVD/AM/FM head unit; Build house w/ huge garage with a drain and a lift.
Please Visit My Web Site (Updated Daily) and Sign My Guest Book
[This message has been edited by lariat4wd (edited 01-25-2001).]
Old Jan 25, 2001 | 01:10 PM
Raoul's Avatar
25 Year Member
Talking
I knew that cap'n, I was just jerking your chain.
Old Jan 25, 2001 | 04:08 PM
harleyrules's Avatar
Post
I have the weather tech visors and they do not use any tape, they fit between the weatherstrip and the window. It is a pressure fit so they don't fall out and they don't make any noise. Plus they come off so you can really clean your windows without cutting your hand.
HD F150
2000 FLHTCUI
1970 OLDS Cutlass W 31
Old Jan 26, 2001 | 12:35 AM
Post
sorry guys I was talking about something different. The vent shades I have are fine and absolutely no problems with them.
The ones where the doublesided tape wore out are these thing made by V-tech that cover the smaller side windows of the x-cab. They attach directly to the window with double-sided tape. Thats what I was talking about.
Sorry guys, got confused.
Old Jan 26, 2001 | 08:36 AM
ragarm's Avatar
Question
Hey Harleyrules! Where did you pick up your Weather Tech visors?
* 2000 F-150 XLT Black FS; 5.4L
* 4x4 ORP
* 3.55 Limited Slip
* Stepups
* Sliding Rear Window
* 6-Way Power Seat
* Remote Keyless Entry
* Lund Trident Bug Shield
* Custom Exhaust
* Fumoto Oil Drain Plug Valve (a must for do-it-yourselfers!)
* Wise Bedrug
So many mods, so little cash! On the up side, no wife to create a filibuster.
Old Jan 26, 2001 | 10:33 AM
Travis W's Avatar
Post
Yeah, Where did you find the weather tech ones. How would they fit in the rubber on the extra cab windows? I would like that, no cut hands sounds great.
Old Jan 26, 2001 | 01:52 PM
Steve GG's Avatar
Smile
I also have the weather tech vent shades and ordered mine from:
http://www.macneilauto.com/store/
I like the fact they don't tape on.
Old Jan 27, 2001 | 12:42 AM
Post
I got my weather tech visors from JC Whitney, they are only for the front doors, I don't have any over the x cab door windows
HD F150
2000 FLHTCUI
