LED Third Brake Light??
Old Apr 1, 2005 | 04:00 PM
smaug's Avatar
Be glad you're coming through Wed and not Mon. The Masters golf tournament is next week and traffic on I-20 in the area will be a monster. What time are you coming through?
Old Apr 1, 2005 | 06:20 PM
01GreenCrew's Avatar
I forgot the Masters was next week. It will probably be about lunch.
Old Apr 1, 2005 | 06:43 PM
smaug's Avatar
I NEVER forget the Masters. I always stay away from that side of town when they're playing. Wouldn't mind getting a close look at your truck but I'll be in a training class when you come through.
Old Apr 5, 2005 | 04:50 PM
Dman25's Avatar
Originally posted by smaug
59.95 plus shipping
http://karkraft.com/f-series.htm
That's one hell of a deal!
Old Apr 11, 2005 | 06:09 PM
hawkfxr724's Avatar
Question Install question....
OK,
I got my LED light in from Kar Kraft. Unfortunately, no directions are included.
I go and remove the OE light, how in the heck do I unplug the OE light and install the new one??
OR..do I clip the wires that go to the OE one and splice the LED one in?
SOMEONE HELP!!!! PLEASE???
DC
Old Apr 27, 2005 | 08:46 AM
hksigman's Avatar
did you get it installed yet? how did you attach the wires? i was thinkin of orderin one for my truck
Old Apr 27, 2005 | 10:57 AM
31Charlie's Avatar
Wow, those prices are great. They say they are OEM parts? Seems too good to be true.
31C
Old Apr 27, 2005 | 01:56 PM
hawkfxr724's Avatar
It's a Ford part!
31Charlie,
I ordered mine from Karkraft.com and was pleasantly suprised to see it was a Ford OEM part.
As for the installation...wow. It was an adventure!
I consulted Rockpick and a couple of other folks on here who have them installed.
This is from Rockpick:
First and foremost, secure your sister's help if she has tiny arms/hands.
What you'll have to do is drop the rear end of your headliner within the cab. It's a plug that runs from the unit out to a connector and, to my recollection, it's located on the passenger side almost immediately above where the rear passenger would be seated.
Fortunately, my wife is kind of tiny and thus, I had her reach up beneath the headliner to unplug and replug my LED (when I had it). She did this with a VERY minimal 'flex' in the headliner which did not leave any creases or similar.
Be patient... it can be a booger.
It may help if you have a rear sliding window to do EVERYTHING from the bed of the truck as it's a better angle to reach up and beneath the headliner...
Best of luck!
-RP-
I also had help from 01GreenCrew:
What Rockpick said. The point where it has a connector is attached to the roof of your truck. I pulled mine loose from the roof so I could pull the connector appart more easily, and I have a rear slider so I could get at it easier. To keep from creasing my headliner, I pulled the plastic plugs out of the headliner and removed the coat hooks and dropped it down just a little bit.
This is what I had to do:
I guess since I had Ford install my power moonroof after I bought the truck, they did some modification of their own to my headliner. I attempted to lower it like you guys said, but it wasn't going to budge. So I gently peeled the headliner cloth off the headliner, just to get a view of what ws under there. I find 2 self tapping screws and washers holding the headliner to the metal thats under the "roof".
A lot of the OE headliner had been cut out to make room for the power moonroof. So, I cut a little more and found the plug!
Everything after that was a breeze. I've got some 3M Spray Adhesive which I can use to reattach the headliner cloth I peeled down, but is there anything that I could use to replace the cut out headliner foam?? Would anything stick to the metal and stay stuck??
If you have a moonroof, it'll be a little more difficult;if you have a moonroof that was installed after you bought the truck, you'll have a REAL interesting time! But with patience and a steady hand, you can do it.
I LOVE the light! It matches the Line of Fire I have under my tailgate and it's BRIGHT!
Good luck and order with confidence from KarKraft.
DC
Old Apr 27, 2005 | 02:58 PM
31Charlie's Avatar
31Charlie
Wow, so does that mean those headlights and taillights are SVT parts as well? Not that they are "cheap" those are still the best prices around I found.
31C
Old Apr 27, 2005 | 04:32 PM
hawkfxr724's Avatar
I'm guessing they are...you could always call and ask. It was super-fast shipping also.
Good luck...
DC
Old Apr 27, 2005 | 04:44 PM
31Charlie's Avatar
Good luck...
DC
Shipping isnt really an issue. I got time, lots of time...
31C
Old Apr 27, 2005 | 06:42 PM
hksigman's Avatar
anyone know if the LED light will fit a 2005 f-150?
thanks
matt
Old Apr 28, 2005 | 07:50 AM
31Charlie's Avatar
no it wont.
31C
