window stuck...down
Old May 28, 2004 | 12:22 AM
porky's Avatar
window stuck...down
my pasenger side window is stuck down. took door apart and tried to remove motor to see if that was that was the proble, but i cant remove it. the motor is getting power, and if i press down, i can hear it click like its trying to do something, but if i press up, nothing happens. i thought it might be jammed or something, but the window wont budge when i try to pull it up. is the motor just fried or something else. should i just replace the motor myself or bring it in to the dealer...ugh
Old May 28, 2004 | 12:31 AM
sleddogg's Avatar
porky,
Did ya check the switch to see if it works when pressed for up.
Could just be that half not working.
Sled...
Old May 28, 2004 | 06:40 PM
lifeguardjoe's Avatar
Originally posted by sleddogg
porky,
Sled...
My thoughts exactly
Old Sep 20, 2004 | 06:46 PM
fireman467's Avatar
Get it fixed yet? I'm having the same problem and trying to find the solution. I too can hear the relay when I press the switch. I ripped the door apart to get to the guts. My motor gets really hot, but will not roll up...
-Michael
