Projector Problem
Old Apr 11, 2004 | 05:13 AM
WardenKhan's Avatar
Projector Problem
Hey guys, I just installedsome projectors (use the link to see what which ones) http://images.andale.com/f2/113/106/7509361/1077370373271_97F1501PC.jpg
I installed them and everything is great except when I turn my lights on the high beams come on instead of the low beams, and I have to turn on the high beams to use the low beams, I'm not sure what the problem is.. maybe someone can help?
Old Apr 11, 2004 | 07:05 PM
Invalid_access's Avatar
Sounds to me you got the high beam and low beam wires backwards. Did you have to cut off your 9007 connectors to get those to work. What kinda bulbs are you running in that.
Old Apr 11, 2004 | 09:04 PM
WardenKhan's Avatar
The blubs ar H3 for low and 9005 for high and all i did was slpice the LED at the bottom into the park lights
Old Apr 11, 2004 | 11:00 PM
To get those to work. You would have to connect the something to the 9007 socket. If I my thinking right. Somehow they are working backwards. Maybe the harness that hooks up the two headlights was wired backwards. That is all i can figure. They look really good though.
