amp and speaker question
Old Jul 28, 2002 | 06:19 PM
FreeMoney's Avatar
Is it possible to run two speakers on 1 channel of the amp? Meaning attach two positive and two negative wires to one channel on the amp? What would this do?
Old Jul 28, 2002 | 09:34 PM
2Trucks1Wife's Avatar
It all depends on your amp. It is possible to run 2 speakers off of 1 channel. When you run 2 speakers off of 1 channel it changes the ohm load on the amp. If you have two 4 ohm speakers (most speakers are) when you wire them together you will have a 2 ohm load. If you amp is 2 ohm stable you will be fine.
John
Old Jul 28, 2002 | 10:26 PM
FreeMoney's Avatar
Thnx...yeah the amp is a Rockford Fosgate 500X. It should do just fine.
