Help!!!I Need assistance please.
Old Jun 24, 2002 | 10:47 PM
Peacemaker's Avatar
I am currently using a Kenwood cd-player with Infinity aftermarket speakers in the doors. And the sound could use a little help. I am looking at a Rockford Fosgate 2ch. amp to juice things up a bit. I've also been pondering on how to run the speaker wires. O.K. here goes---> 1. Mount amp behind driver's seat. 2. Connect all + & - power wires, with the main + wire running from the battery, and the ign. wire going to + in fuse box. And the - wire grounded behind back seat under vinyl carpet. 3. Run speaker wire under the vinyl(where the hump is for the tranny) from headunit to amp input. 4. Run speaker wire from amp output under the doorsills and behind the kickpanel up to the rubber tube in between doorjambs and cab of truck. 5. Run wires through rubber tube. 6. Take door panels off so you can have access to speakers. 7. Connect speaker wires. 8. Put door panels back on. 9. Put in your favorite cd. 10. Enjoy your music! Does that sound right?
Old Jun 25, 2002 | 09:02 AM
Ascii's Avatar
Thats basically it but you dont need to run a ground back to the bat. just ground it to a seat bolt (scrape the paint off from under the bolt for a better ground) and what are you talking about an ignition wire?? your amp is hooked up to your remote wire from your radio . is that what you are talking about?
LATER
Old Jun 25, 2002 | 12:04 PM
Peacemaker's Avatar
Yes. Remote wire, that's what I meant. I could'nt think of the name of it. Thanks for the tip on the ground wire.
