Calling all "Switch" people
Old May 28, 2002 | 11:36 PM
Ascii's Avatar
I am wondering where you all are placing switches in your trucks i
have looked for a spot to make a hole that wouldnt kill me if i had
to remove and sell but i have yet to find any if there is anyone
out there that has a place to put it so its not as noticeable or
that it looks really good please post pictures or tell me in detail
where it is. thanks
Old Jun 12, 2002 | 05:29 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Exclamation
If you have an aftermarket Head unit, you can install them above it in the flat space of the install ring. That's where I had mine before I installed an equalizer. Now I'm looking for a place to put them again as well. I am thinking of making a panel for them that can be double side taped on the lower dash somewhere. Other than that, drilling a hole in an easily replaceable dash part is another solution. That way you'd only have to buy a new or used dash piece to return it to stock.,,,,98
Old Jun 12, 2002 | 05:37 PM
98SCREAMER's Avatar
Smile
One way to make them look there best, would be to buy some matching switches from the auto parts store. That way when there are spaced close to each other, they will look more uniform. The led tipped switches look great to me, that's the ones I plan to use when I redo my switch "array".,,,,98
Old Jun 12, 2002 | 05:38 PM
Ascii's Avatar
I think i have found a solution and that is to make it as "stock
looking" as possible i am going to install two smaller non-
illuminated switches in the door where the p/w and p/l are at
current there is enough space towards the the back of it to install
them and i think it will look ok. This is what the
Switch looks like. I think it will look
decent in the power housing.
Old Jun 20, 2002 | 09:56 AM
Ascii's Avatar
has anyone placed there switches in the power panel in the door?
