Neon Lighting wiring
Old Jan 17, 2002 | 03:07 PM
98_EXPEDITION's Avatar
Does anyone know how to mount and wire a neon "bar" for automatic turn on from an amplifier? I want to mount it either right above or below my amplifier in my Cargo are of my Expedition.
http://images.cardomain.com/installs...72_38_full.jpg
Old Jan 18, 2002 | 11:31 PM
adamski's Avatar
There are a few different options to connect it.
You could run a new wire from the fuse block, connected to the fuse of your choice for lighting with the ignition.
You could run the wire like above only connecting a switch for manual control from the drivers seat.
You could splice the remote wire just before the amp-- If you do this, depending on how much current you will be draining, you might have to install a relay. If the remote wire is connected to the back of the radio, I would highly suggest using a relay.
