wiring in amplifier
Old Apr 12, 2013 | 06:20 PM
Veteran: Army
wiring in amplifier
just wondering where you are hooking up the power source for your amps in the '97-'03 F-150's
Old Apr 12, 2013 | 07:25 PM
pizzaman711's Avatar
You mean how it's being hooked to the battery? Or like how it's being routed through the cab?
Old Apr 12, 2013 | 10:26 PM
Veteran: Army
where is it getting power when the key is on
Old Apr 12, 2013 | 10:48 PM
mine goes to the back of the radio for the trigger wire
Old Apr 12, 2013 | 10:52 PM
Yea my radio has a remote turn on lead, but you can always do the add a fuse technique.
Old Apr 12, 2013 | 11:23 PM
It should be spliced to the (I believe red) 12 volt wire in the back of the radio, that way it turns on at the same time and way the radio does
Old Nov 17, 2013 | 08:37 PM
mikecu's Avatar
I believe that the red comes on when the key is turned on. Is there a wire that goes on and off with the radio? They used to call it the power antenna wire way back in time.
Old Nov 20, 2013 | 12:08 AM
K.R.newbie's Avatar
yellow is switched red is battery
