Infinity Basslink
Infinity Basslink
A few years ago i had an Infinity Basslink given to me so i figured what the hell, and wired it up. The thing has worked great for the last two or three years. Well today I got into the truck to come back from class and there was no bump. So when i got back i checked all of my connections, my fuse out on my power feed from the battery and the fuse that you can see on the side of the amplifier itself. everything checks out. When i turn the key on, the litte red power light comes on, but there is a little green light that says 'servo' i think that is not comming on any more. I am going to take the cover off this weekend and take a look for a bad solder connection or something.
Anybody else have this problem with this set up or just a similar experience? any input is greatly appriciated.
Shortly after i posted the thread, the thing came back to life. Then, a couple of days ago, it stopped working today. After determining that everything was functioning (all lights working and all wires powered) and the only problem was the lack of sound i tore it apart and discovered after fiddling with it, a bad connection somewhere between where the wires hook to the tabs on the speaker itself and the cone. i have it working now, but it is a matter of time before it cuts out again. Does anyone know where i can find a new speaker for this thing? or if a normal ten inch sub will fit the box? thanks
https://encrypted-tbn1.google.com/im...J1Q1U2ajkIB9rg this is a picture i found online, just for reference of what i am working with.
