is this a decent amp?
Old Aug 9, 2011 | 07:24 PM
oxfordbp's Avatar
ZRS-C9 CADENCE 4 CH 1000 W AMP to run 4 Pioneer Ts-D6802r?
OR
CADENCE F400-4 1000W 4-CHANNEL
Old Aug 9, 2011 | 08:44 PM
Langlowe's Avatar
I am partial to the ZRS but either would work. If you plan on upgrading to 6.5 components later on then the ZRS for sure.
With the ZRS you would have to be careful with the gains or you could mess up the Ts-D6802r.
Old Aug 9, 2011 | 10:14 PM
oxfordbp's Avatar
Great thanks.
Old Aug 10, 2011 | 12:43 AM
mSaLL150's Avatar
Use the ZRS between those two. It is one of Cadence's good quality lines.
Old Aug 10, 2011 | 03:58 AM
air8's Avatar
I've never heard of Cadence. They are decent quality? Like goods for normal stereo upgrades?
Old Aug 10, 2011 | 09:09 AM
Stormsearch's Avatar
25 Year Member
I have their iA4 driving my Hertz components and it is great clean power. I have 4 ch bridged to 2 ch for 250W each. They were a solid company that put out clean power. I know they had some Zed design build/input on the early A series which lead to their Poison line - one of the best amps around. Their higher end amps were always underrated, the lower end stuff I would probably buy something else.
Old Aug 10, 2011 | 09:18 AM
Langlowe's Avatar
Do a search for rival904. He was using the ZRS amps for an over the top SPL build.
He has since moved to DD but I have read pretty good reviews for the ZRS.
Old Aug 10, 2011 | 12:27 PM
mSaLL150's Avatar
I use their iA7 to push my BMs. It is rated 1000-1200 RMS and it benched at 1225w. Already survived 3 really hot summers behind the backseat, has never given me a problem.
Old Aug 11, 2011 | 06:40 PM
oxfordbp's Avatar
OK, I will get the ZRS series and run my door speakers off it!
Now, How do I get my door panels off!?
Old Aug 12, 2011 | 05:52 PM
Langlowe's Avatar
This should help. Might be a little different with your 2007.
https://www.f150online.com/forums/20...head-unit.html
Old Aug 12, 2011 | 10:56 PM
oxfordbp's Avatar
Awsome thanks
