340 watt amp
Old May 18, 2011 | 12:38 AM
Johnnyjb's Avatar
340 watt amp
my friend is giving me a 340 watt amp and i was wondering if i could power my door speaker on this
and will it make any difference at all?>
Old May 18, 2011 | 01:04 AM
Johnnyjb's Avatar
would this be able to power 2 10 inch subs?
Old May 18, 2011 | 01:07 AM
jpf150's Avatar
We need some specs on the amp, door speakers and subs. Is 340 rms? max? At what impedance load?
Just give us the model numbers of this stuff and we(or at least I) would be more than happy to help you out
Old May 18, 2011 | 01:09 AM
Johnnyjb's Avatar
i have no idea im asking right now
and i wouldnt be sure on what kinda of door speakers i could buy
My friend has a box with 2 10 inch Kicker subs in them that he would sell me for 50 bucks so i have no idea if it would run haha
Johnnyjb's Avatar
I was just told it was 340 watts peak power and 340 watt rms
2 channel 4 OHMS
Old May 18, 2011 | 01:27 AM
jpf150's Avatar
Usually the peak is more than the rms..hmmm. If it is rms and you powered 2 subs with that then each sub would be getting 170 watts, if wired at 4 ohms. For some kickers, 10's most likely like you have mentioned, their rating is 150 watts. So yes if wired at a 4 ohm impedance, subs getting power that is within spec, and the amp is actually 340 rms, then I would say it is a go.
Now, you will not be getting any super hard hitting bass, but for $50 for the whole setup I must say I probably wouldn't pass it up.
Old May 18, 2011 | 01:30 AM
jpf150's Avatar
kicker with 150 rms....http://www.sonicelectronix.com/item_...04-07C104.html
amp with 170 watts rms per channel at 4 ohm....http://www.sonicelectronix.com/item_...-KAC-7205.html
Old May 18, 2011 | 09:48 AM
Johnnyjb's Avatar
im not looking for super hard but like a good little bass that you notice i have a sub.
My girlfriend despises my friends 12" sub at like half power so i think i should be fine haha
Old May 18, 2011 | 09:53 AM
jpf150's Avatar
I would say go for it. The worst that could happen is you are out ~70 after you buy the wiring for it. I would just make sure all the components work fine before you buy it.
Old May 18, 2011 | 05:56 PM
Johnnyjb's Avatar
i decided to just save up money and go some what legit
and something that will fit in my truck better.
so maybe an 800w amp and a 10" sub
Old May 18, 2011 | 06:03 PM
jpf150's Avatar
Just find an amp and sub that are in spec with each other and you will be golden. Look at the rms, that is more meaningful than max.
Old May 18, 2011 | 06:04 PM
Johnnyjb's Avatar
idk how to do that haha
im looking to not spend more than 100 on both tbh :/
Old May 18, 2011 | 06:06 PM
jpf150's Avatar
If you are not looking to spend over 100, I would get the deal from your friend. You will have to buy used to stay under that budget.
Old May 18, 2011 | 06:10 PM
Johnnyjb's Avatar
around how many wattage are most little 8 inch subs
Old May 18, 2011 | 06:13 PM
jpf150's Avatar
Look on sonicelectronix or crutchfield for what you may want.
