factory amp ?
Old Mar 13, 2011 | 12:23 PM
harley41's Avatar
factory amp ?
I have a 97 f-150 ext cab 4x4 lariat, it has premium sound, I'm trying to find out some info on the factory amp, any known problems,etc. I'm putting in a new sony 2 din HU tomorrow, was wondering if this amp would be ok to use. any help or input would be appreciated thanks, Harley
Old Mar 24, 2011 | 05:29 PM
BL4CK3D0UT's Avatar
They should be fine to use, just make sure to hook up your amplifer turn on wire to the correct wire. If it does have a problem and sounds bad, you can bypass the amplifier
Old Mar 26, 2011 | 02:03 PM
harley41's Avatar
thanks man for input, i used scosche harness for premium sound, i'm assuming its fine, but i still have a power draw on my audio fuse in the PDB, i think it's in the factory amp. thinking of putting it on a switch thanks again.
