Factory Sub Harness
Old Mar 16, 2011 | 04:28 PM
mcanavan69's Avatar
Factory Sub Harness
Does anyone know where I can get a harness to run from the sub out of my factory unit to the rear of the cab? I have a 2010 S-Crew with a stock unit I put in. I replaced the standard 1-disc am/fm with the 6-disc am/fm sat ready unit with the sub out. I just need the harness to run to the back of the truck to spice in an aftermarket amp. I know I will have to run power from the battery, I just want to use the stock harness for signal and remote.
M
Old Mar 20, 2011 | 06:42 PM
thirdgenbird's Avatar
i do too...
Old Mar 21, 2011 | 12:56 PM
38Blackfin's Avatar
My 08 Screw, the harness is there. The radio end was taped off to one side, I haven't checked under the rear seat, but it has to be there.
I went from the factory single disc to a Shaker 6-disc from a 2006 Mustang; I plan to use the factory harness from the radio to drive a JL Stealthbox sub and amp.
good luck!
Randy
Old Mar 22, 2011 | 08:50 PM
good luck!
Randy
i'm working on a fusion but i'm hoping i find the same thing.
do you know if the sub output on the factory radio is line level or preamp?
Old Mar 23, 2011 | 01:07 PM
38Blackfin's Avatar
Don't know, wondering the same thing.
Randy
Old Mar 28, 2011 | 12:44 PM
mcanavan69's Avatar
Thanks 38, I'll do some digging
Old Mar 28, 2011 | 03:32 PM
38Blackfin's Avatar
I'm heading to my audio guy tomorrow to get my box put in, I'll ask.
Randy
