amp is this good? need amp
Old Dec 1, 2010 | 12:33 AM
mote88's Avatar
http://cgi.ebay.com/CRUNCH-1000-WATT...item5add58aaee
is this a good amp to power 2 kicker cvt 10s and maybe door speakers later down the road?
thanks new to all this audio stuff
Old Dec 1, 2010 | 01:40 AM
joh408's Avatar
Doubtful. Couple buddies decided to try a few out after seeing them so cheap, amp over heated and went into protection mode at least once a week, if not a day
Old Dec 1, 2010 | 02:33 AM
abervintageman4's Avatar
crunch is owned by hifonics, only crunch amps worth buying is the gdp3000, other than that i would pass on it
Old Dec 13, 2010 | 05:16 PM
Louderisbetter1's Avatar
That amp is on 2 channels, which means it can only run the Subwoofers OR the door speakers. What i mean by this is the crossover on it will be for bass only OR for Mids and Highs (door speakers). If you want to combine your door speakers and subwoofer on one amp you'd have to go with a 4 channel or 5 channel amp. Only difference between those is the 5-channel amps have a seperate connection for subwoofers, like having 2 amps in 1 (which is what I would recommend over the 4 channel). Crunch amps are good bang for your buck IF (and only if) you have a good electrical system to supply power and GREAT GROUNDS (make sure to research power, grounds ,size Gauges you need, batteries and BIG 3 electrical upgrade extensively before buying any wires). Thats what causes over heating and protect. I used to have a 4 channel crunch pzi1000 about 5 years ago, NEVER had a problem with it had it Bridged 4ohms Sucking every watt I could get out of it (Maybe 600 watts at most even though it was a 1000 watt amp) and it did a h*ll of a job for 70$. I'd honestly just go with a monoblock Class D Subwoofer amp and get a 2 or 4 channel amp later for the door speakers. For subs look at
http://cgi.ebay.com/AUTOTEK-SS1000-1...ht_2456wt_1002
http://cgi.ebay.com/HIFONICS-BRUTUS-...ht_1808wt_1139
http://cgi.ebay.com/PLANET-AUDIO-TQ1...ht_2986wt_1024
http://cgi.ebay.com/AUDIOPIPE-1000W-...#ht_4791wt_918
In all cases buy 2 dual 4ohm CVT subwoofers and connect them @ 1ohm to those amps
GOODLUCK!!
Old Dec 28, 2010 | 10:50 PM
Rufus269's Avatar
check pm
