2010 SCREW amp board dimension
Can anyone give me a maximum size of their amp board for behind their rear seat in a 2010 SCREW? I currently only have my Kappa 4 amp but plan on adding a mono amp in the near future for a sub. I don't want to run out of real estate on the amp board when I go to add another amp. How high up should the amp board be mounted to not interfere with the seats folding up or down?
Here is my install.
https://www.f150online.com/forums/sp...g-writeup.html
I got 18x28 on mine. However, I am having to redo it and should be about 18x42 in a L shape. Bought a different much larger 4 channel amp and now have to go sideways.
My amp board spans the back cab wall form side to side and is at a height that it just touches the bottom of the brackets that the seats latch to. The problem I ran into was the space that is available between the seats and the board varies greatly depending on if the seats are up or down.
I've written a post about my experience: https://www.f150online.com/forums/20...rear-seat.html
There is room back there but not what you would initially think, especially when the seats are up.
