easy place to mount a amp?
See if this helps you, I will be doing this soon, haven't tried it myself though.
http://www.ford-trucks.com/article/i...2008_F150.html
yeah that should help but i just did it using a long screwdriver to hit the latches. it took awhile to figure it out at first but now i can do it in a few minutes. theres a how to on here i believe that uses a screwdriver.
Correct, but the tabs are not needed at all. The hooks at the top of the seat back are what holds the seat in place, so since the tabs were not needed I just cut them off completely and you never have to worry about them again.
Is there no risk of it coming off in an accident? It'd be nice not to have to fight those clips again.
In a roll over, the seat could easily slide up, and the weight x force of the seat back coming up in a roll would pull the seat belts tight around who ever is sitting in the rear seat.
Only possibility of it being more dangerous to disengage the tabs, though I think that if enough force were exerted on the rear seat that the two bolts holding the plastic seat belt piece on the top of the seat were stripped or simply broke the plastic and went down through it that the tabs would not stand a chance anyway.
If I were in a rollover, the seat staying in place would be the least of my worries. Just keep the truck shiny side up and you're good.
Hey to remove back seat do I need to remove seat belt? I don't have that tool to remove seat belt. I just orderd a JBL GTO14001, that amp is long 18" 1/2. Would a pieace of plywood work great to mount amp? Our should I just mount with out plywood? Any help would be great thanks.
Even with my big adz hands and huge forearms I can get the seat unclipped in seconds once I figured out the trick. I shove my hand through the junction between the top/back, palm down. I can maneuver just enough to get my thumb on the release tab. Takes very little pressure, the tabs aren't stiff at all. Put some pressure on the tab, give the top of the seat a light tap, and the pressure of having my arm shoved in the junction causes the seat to pop right up.
Brad
Brad
I dont have pics on my computer just yet but i have my amp mounted on the headliner dead center at the back.....looks pretty cool back there....oh plus its a US Amps 100 hc.......so it is a showpiece
