What size of amp?
What size of amp?
I am getting an MTX sealed Box that comes with a Thunder 4500 10" in it.
I am wandering what Amp I should get? I think I have narrowed it down to 3. Can someone help me choose, I have no clue on the difference on watts and RMS. I want it to last awhile, but not be underpowered.
Im looking at:
1. Alpine - 500W Class D (Model number: MRP-M500)
2. Power Acoustik - 420W Class AB Bridgeable 2-Channel
(Model number: LFA2-420)
3. MTX - 200W Class AB Bridgeable (Model number: TC2002)
Can someone please tell me what the Class difference is, and what to go with.
I thought that the Alpine was the best bet, but I have no clue.
Thank you!!
Im looking at:
Thank you!!
As for the OP, it really depends on the impedance load of your woofer like SunDevil2188 said. But out of the amps you chose, I'd go for the Alpine MRP-M500. If your sub has a single 4ohm voice coil, the amp will push 300Wrms, which is more than plenty for your woofer. If your subwoofer is dual 4ohm on the voice coil, then the amp will push around 500Wrms. Honestly, both numbers present a danger of overpowering, but that's where you just set your gain to the proper level and you won't have that issue.
I just checked the specs on the woofer, and no matter what the ohms, the peak rms is 225. So if the alpine pushes 300 would this be bad?
I believe that it's only a 4 ohm. Not dual or 12. Lol. Is there Any way to tell by looking at the speaker?
The best way to tell on the speaker is to see how many pairs of terminals it has. One MTX subwoofer sold by itself in a box will never be 12 ohms. Also, the subwoofer cna handle 225Wrms regardless of the impedance, but if you're loading the amp @ 2ohms, it will push 500Wrms unless you know to turn the gain down. But since you think it's a single voice coil subwoofer, then the MRP-M500 amp will run around 300Wrms @ 4ohms. It's not bad to run more than the rated power, just be sure to tune your amp properly with the gain slightly lower if you're concerned about blowing out the woofer.
Ok, So I have settled on a MRP-M450. I found a guy here in town, that was selling one on craiglist.
It is working, and is letting it go for cheap. He was pushing 2 10's with it. I don't know how he did it, because its only a 1 channel.
I hope that this is a good decision on my part.
Well mainly, unless you intend on exceeding the limits of the subwoofer, I wouldn't exceed the limit of the subwoofer. Realistically, you can't expect a whole ton of bass out of a 10" woofer. All I know for certain is the MRP-M450 will compliment the 10" MTX 4500 just fine. Just don't crank the crap out of the gain to make it sound louder. That will destroy your amp and subwoofer. Tune it properly and that is the best you can get out of your amp and subwoofer without running into trouble.
Well mainly, unless you intend on exceeding the limits of the subwoofer, I wouldn't exceed the limit of the subwoofer. Realistically, you can't expect a whole ton of bass out of that 10" woofer. All I know for certain is the MRP-M450 will compliment the 10" MTX 4500 just fine. Just don't crank the crap out of the gain to make it sound louder. That will destroy your amp and subwoofer. Tune it properly and that is the best you can get out of your amp and subwoofer without running into trouble.
