ARC or Phoenix Gold
Old Dec 2, 2009 | 01:28 PM
marcus1033's Avatar
ARC or Phoenix Gold
Narrowed my amp choices down to two sub amps. ARC FD 600.1 or Phoenix Gold 600.1 to power my ID 10 v.3. What do you think? I already have an ARC FD 2200 to power my highs, so the ARC would match but would never be seen. Also, looking at the Kicker PKD4 for power wires.
Old Dec 2, 2009 | 02:08 PM
marcus1033's Avatar
Actually I found a Tsunami 4/8 G dual amp kit + distribution block + RCa which includes all wires that I will need for $75. Is this a good deal for my system.
ARC FD 2200 amp
pluse one of the two ARC 600.1 or PG 600.1 amps.
Old Dec 2, 2009 | 02:26 PM
PorkCereal's Avatar
Been reading decent things about ARC amps. If your set on one for ur subs, id go same all the way around. I have no expierience using them.
Check Knukonceptz.com I think they had 4g kits for like 40$. You will probably want 2 blocks for ground and power.
Old Dec 24, 2009 | 11:55 PM
One Shot Luni's Avatar
I know this is an old thread but ARC amps are pretty decent. I had the same fd 2200 running two kicker comp 10s with it turned all the way down and it pounded.
Old Dec 25, 2009 | 01:38 AM
mSaLL150's Avatar
If the PG is one of the older Xenon versions, I'd be hard pressed to turn that down.
Old Jan 11, 2010 | 10:13 AM
profarm72's Avatar
I just installed the Arc KS1000.1 on a JBL 10 DVC set @ 4 ohms and I love it.
I highly reccomend Arc Audio.
Old Jan 11, 2010 | 12:22 PM
kuruption's Avatar
Arc Audio over PG anyday
Old Jan 11, 2010 | 12:52 PM
marcus1033's Avatar
Old thread. I hear ya, I am actually deciding on the Zapco (used) or Arc.
Old Jan 11, 2010 | 08:03 PM
kuruption's Avatar
I run Zapco, and I would recommend it first and foremost if you can afford it. You can do pretty decent finding a used one on ebay... just make sure if you do, it still has the serial # attached or Zapco won't service it at all.
