Amp board.
Old Nov 17, 2009 | 07:15 PM
Amp board.
Been doing a lot of searching lately on back wall amp installs with an amp board.
How are you guys adhering/mounting the board to the back wall?
Sorry for the dumb question. :o
Old Nov 17, 2009 | 08:11 PM
JJDH's Avatar
self tapping screws. there are raised gussets back there to screw into
Old Nov 17, 2009 | 08:39 PM
Ah, ok. Makes sense. I've never seen back there and all the pics I saw from searching were of the finished product.
Old Nov 17, 2009 | 08:45 PM
JJDH's Avatar
Old Nov 24, 2009 | 05:51 PM
wmitch927's Avatar
If you look close, I have 3 self tapping screw across the top and 3 more as low as I could get them and still hit the raised section on the back.
Old Nov 24, 2009 | 10:12 PM
cheef's Avatar
Is it worth putting dynomat over all that steel back there? Thinking more for road noise than accoustics...but maybe both?
Old Nov 24, 2009 | 10:47 PM
mSaLL150's Avatar
Abso-****ing-lutely. And seal the vents.
Old Nov 25, 2009 | 12:13 AM
wmitch927's Avatar
^^^ x2. I'm a little short on money and time right now, so I just got it done. Now that everything is wired, I can go back later and dynamat. The back seat rest removal is easy after you do it the first time. Kinda like sex, I guess.
Hey Sall... Someone posted on this forum somewhere that they covered they're vents and now get a whistling sound inside the cab whenever they turn the heat/AC on high. Did this happen to you?
Old Nov 25, 2009 | 11:08 PM
Impact9's Avatar
I've covered mine too. Aside from the slight increase in pressure nothing noticeable has changed.
Old Nov 27, 2009 | 01:53 AM
mSaLL150's Avatar
Yeah, if its on super high you might get a slight whistle. Mine is never higher than 3 bars so its fine. If you run the vents on high a lot, then cover one vent completely and cover half of the other one.
Old Nov 27, 2009 | 12:46 PM
kingofthegeeks's Avatar
I had to do just that, i had covered the whole back wall and all was fine until it got cold and my fan was running on high, i could actually feel the pressure in my ears when the fan was cranked. I just cut out half the one side and now it is fine. Although when the fan is on and you approach the truck you can sure hear the air rushing out the cabin port.
Old Nov 29, 2009 | 09:57 AM
yellow stx's Avatar
I had mice jumping up from the frame into the vents and made nests behind the carpeted panel, smelled like hell
Old Nov 29, 2009 | 11:31 AM
Old Nov 30, 2009 | 02:48 AM
57 rag's Avatar
You gotta be ****tin me!! seriously?? Holy hell, what holes are those and how can I plug them? Already bustin out the welder!
Old Dec 5, 2009 | 09:10 PM
Cdn-Redneck's Avatar
I used constuction adhesive (pl-500) and glued the MDF to the back wall. Installed an amp and a thunderform without drilling any holes into the truck.
