amp question
Old Sep 9, 2009 | 08:04 PM
pecanfarm's Avatar
amp question
i have 2 subs rated at 300w rms at 4 ohms...i found an amp at RMS Power Output: 2 x 250 W @ 4 Ohms...is that adequate enough to push my subs?
Old Sep 9, 2009 | 08:10 PM
JJDH's Avatar
go big now instead of later. what brands u speakn of?
Old Sep 9, 2009 | 09:28 PM
se7en's Avatar
are your subs dual voice coil or single and what is your amp rated for 2 ohms?
Old Sep 10, 2009 | 12:45 AM
FX4SCrew05's Avatar
I am assuming your subs are single voice coil 4 ohm each. Firs off what brand is the amp? Subs? If it is 250X2 RMS @ 4 ohm, even in stereo at 4 ohm it would push your subs nicely. IF it is a good quality amp and is a true 250 X 2 rms. Also depending on the brand and quality you might be able to bridge those two 4 ohm subs so the amp "sees" a 2 ohm bridged load. Then you would achive the most power and be over 500 rms split between each sub.
Old Sep 10, 2009 | 12:41 PM
pecanfarm's Avatar
They are 12" hifonics dual voice 600 peak 300 rms at 4 ohms
Old Sep 10, 2009 | 12:42 PM
se7en's Avatar
what model subs and what make and model amp?
Old Sep 10, 2009 | 12:59 PM
pecanfarm's Avatar
The amp I'm lookin at is a hifonics zeus I believe a zx1010
