Amp mounting
Old Aug 16, 2009 | 01:23 PM
05lifted50's Avatar
Amp mounting
Ok, so I bought a nice enclosed box for one 10 on ebay that fits very nicely under the rear bench seat of my 04 f150 fz4 supercab, however, I have no idead where i can mount the amp! Theres not a lot of room. I was thinking under that passengers seat but theres an ac vent. Any ideas?
Old Aug 16, 2009 | 02:50 PM
jdruzik's Avatar
I did mount mine under the rear seat... Actually two amps with no problems. I also have the 10" woofer mounted under the seat as you can see. This set will work well and is easy to access...
The top two images show the location of the amps and the bottom shows the custom box that houses the sub woofer...
Old Aug 16, 2009 | 03:33 PM
AntzFreshWhip's Avatar
im not familiar with the different model cabs and how the seats are but in my supercrew cab, i mounted mind behind the rear seat. i bought a small amp , made by sony. its very compact and powers my kickers really well..
Old Aug 16, 2009 | 03:37 PM
JJDH's Avatar
Old Aug 16, 2009 | 04:06 PM
05lifted50's Avatar
Where did you move your jack to?
Old Aug 16, 2009 | 04:07 PM
05lifted50's Avatar
Originally Posted by JJDH
The way you have your amps mounted seems pretty cool. Certainly keeps it outta the way. Is it ok to enclose the amp like that? Doesnt it need airspace? And are the seats hard to remove?
Old Aug 16, 2009 | 05:33 PM
where i keep my jack, well i got a 5.5 ft bed with a cover so i put that to good use.lol...i keep all my cleaning supplies in my truck and all the goodies....
Old Aug 16, 2009 | 05:55 PM
JJDH's Avatar
seats arent bad to remove, the heat is no issue, this is where the amps go... https://www.f150online.com/forums/ar...08-my-way.html
Old Aug 16, 2009 | 06:05 PM
jdruzik's Avatar
My jack is in my tool box with the rest of my tools...
The only advantage to mounting amps behind the rear seats is for the placement of two woofers that take up all the space under the rear seat...
Old Aug 16, 2009 | 06:55 PM
05lifted50's Avatar
Ok great. THanks guys. While ive got your asttention, do you have any suggestions on good spots to cut in a line out converter? ANd wheres a good remote spot?
Old Aug 16, 2009 | 08:43 PM
jdruzik's Avatar
So you're trying to connect an amplifier without speaker-level inputs to a car stereo that doesn't have preamp outputs? It can be done, but you'll need a line output converter to make it happen. My amps do have speaker-level inputs to my head unit and does have preamp outputs therefore I did not have to install a line output converter. Two thoughts on the installation, either under the dash close to the H.U. or as close to amp as possible. I would chose the latter...
Old Aug 16, 2009 | 09:01 PM
i kept my stock hu and had my audio shop put in a line out converter. works great
Old Aug 16, 2009 | 09:25 PM
05lifted50's Avatar
Yeah, ive put them in my other cars before. Im just looking for a good spot. Ill prob go with the rear speakers
Old Aug 16, 2009 | 11:28 PM
JJDH's Avatar
at the hu is recommended for the converter
Old Aug 17, 2009 | 12:04 AM
05lifted50's Avatar
Do you know how i tell which wires are for the speakers?
