Where do you put your amp?
Old Jun 11, 2001 | 11:42 AM
haze10's Avatar
Post Where do you put your amp?
I have a 01 Xcab and want to install an amp. Under the back seat is out as I have a full enclosure for the woofers. Where esle can I put the amp, the passenger's seat has the jack, the drivers has a cable in the middle of the floor. Are there other option. 60/40 front seat by the way.
Old Jun 15, 2001 | 12:03 AM
sundog7's Avatar
Lightbulb
What about behind the rear wall? Drop your seat.
Remove the panel. There should be room to stand your amps up along the floor. I have a Rockford Foz 250a and Kicker Impulse next to each other, in addition to my EFX distribution block on the left side. You should have about 16 inches in height, and about 4 inches in depth to play with (measured from the bottom lip of the floor that the panel sits on) before it tapers up to no useable space. Check it out.
01 Black SuperCrew 5.4; Airaid, Borla Split Rear, Line-X, Matched Tint windows. Black. Black. All Black.
Blaupunkt "Munchen" HU; JL Audio Stealthbox, DiamondAudio M551 components, Kicker Impulse coax (rear), RF250a and Kicker 350xi amps
Old Jun 15, 2001 | 04:56 PM
haze10's Avatar
Post
Don't quite understand. Are you saying that I should remove the rear seat and that there is a removalable panel there? Remember I have the Xcab not the 4 door. I don't belive I have any room behind the seat.
Old Jun 16, 2001 | 02:13 PM
sundog7's Avatar
Unhappy
Yes. That's a problem. I visited a dealer today to look for myself. First, let me clarify amp position. I'm suggesting that you stand them up, so a "side" edge of the amp becomes the "bottom". If you can stand your amp up on your dining table, you should be able to mount it the same way along the rear wall, with the "bottom" of the amp against the floor.
If you reach up behind your rear seats from the floor, do you have any useable space at all before the tops of the seats meet the back wall? That's the space I'm suggesting you exploit, if you have any.
Old Jun 16, 2001 | 06:23 PM
haze10's Avatar
Post
I built a custome enclosure to go under the rear seat. One side a 0.45cf sealed box for a 10" woofer, the other is open top for storage. I think it would be difficult to mount the amp behind it. It looks like under the seat is the only place.
Old Jun 16, 2001 | 11:39 PM
r6racer's Avatar
Post
did you say your jack is under the passenger seat? my 01 xlt 2wd supercab jack was under the rear seat. anyways, ford 3 year roadside asistance, who needs a jack? i have a subbox.net box under my rear seats and a sony xplod amp under the passenger seat. the wiring under the seat has enough length that it will fit around the amp. i unhooked it from under the seat(the clip that holds it in the middle) and it fits fine. the amp isnt even screwed to the floor cause it fits perfect and tight. want pics? email me. r6racing@worldnet.att.net
Old Jun 17, 2001 | 10:39 PM
jsbakke's Avatar
Post
If you install under the driver/passenger seats, make sure when the seats slide back and forth the amp will not be damaged.
98 5.4L, 4" Rancho Suspension with 33" BFG on 16" Weld Racing Rims, Chrome Brush Guard, Stainless Stell Steps, Alpine Stereo with 4 5X7 MB Quards run by an Alpine approx. 400 watt amp and 4 He2 Rockford's 10" subs run by a 800 watt Rockford amp, and CB and Scanner
Old Jun 18, 2001 | 07:57 PM
JBirdZ's Avatar
Post
Hey haze10...
I put two amps in my truck, one under the driver side of the 60/40, and the other under the passenger's. If you pull the front seat out (its in two pieces), you can take that harness that goes to the belt tensioner and seat belt switch and move it over, then an amp can fit in there just fine.
2001 F150 SC Red XLT
4x4 Off Road Package
5.4L V.8 3.55LS
Go-Rhino Grill Guard w/KC o-r lights
Pioneer Premier DEH-P410
A/D/S/ 236is front spks
Alpine SWR1040 Subwoofer
Rockford Fosgate 500.2 & 400.4 Amps
Viper alarm w/autostarter
Old Jun 25, 2001 | 10:20 PM
12Vrep's Avatar
Post
Hey Haze, In my 98 xcab I took the back of the back seat out and trimmed some of the metal supports off and used strong two sided tape and stuck my amp to the wall behind the seat back. With the metal I cut away gone, it fits in there nicely and it is concealed. It really depends on how big your amp is on where you can put it. My amp is only about 6-7 inches wide so I can get away with what I did. In all the years I have been installing the one thing I have learned is it is all about stealth. If they can see it, most of the time they can't steal it. Plus, it looks better when you can't see it.....I hope that makes sense.
98 F150 XLT
4.2 V6/5 Speed Trans.
Mods and Upgrades
Pioneer FHP8800 HU
Pioneer TSA6895 Compression horn 6x8's
Pioneer TSA6865
Pioneer GMX542
MTX Stealth Box w/ 2 8in. subs... mild bass
Compustar SHF-2W-AS
alarm/remote start
Clear corners
Xtang soft cover
Airaid Intake System
Switched the 16 in. XLT
wheels for the 17 in' ORP's
35% Window Tint
Weather Tek Window Visors
Stull Billet Grill
Old Jun 25, 2001 | 11:18 PM
2000 F150 4x4's Avatar
Cool
Aren't you guys concerned about heat? My amp gets warm to the touch even with a fan in it. What about adjusting the amp settings? A one time thing or is the seat back easy to remove?
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Remote Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed, Keyless Entry Mod
1994 SVT Mustang Cobra. #1032 of 5009.
<A HREF="http://home.fuse.net/94cobra/my150.html" TARGET=_blank> </A>
Old Jul 2, 2001 | 11:59 AM
jayntguru's Avatar
I took some pictures of my install and posted them over the weekend. See them here.
http://nx2k.dynip.com/truck/index.htm
That's the main page, then go to the "audio" link on the left.
-Jay
98 F150 4x4 ORP with some stuff
http://www.nx2k.com/truck/
Old Jul 11, 2001 | 11:56 AM
haze10's Avatar
rear seat
jay, how do you get the rear seat out. I see the bolts for the bottom cushion, but how about the back vertical, are there bolts or clips and do i have to remove the bottom in order to take out the back.
Old Jul 11, 2001 | 07:00 PM
jayntguru's Avatar
Once you remove the bottom bolts (there are two 10mm bolts) then you just lift the seat up. It's easier than you think!
-Jay
98 F150 SC 4x3 ORP w/stuff
Old Jul 18, 2001 | 06:13 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Unhappy
Hey jayntguru,
I put my amp in the exact same place. During a really hot day the sub channel blew. The amp began cutting in and out even at low volumes. I felt the floor around the amp and it was HOT!! I had no idea that area of the floor got up that high? If I put my next amp there,I am definitely laying down heat reflective matierial under the carpet. I hope that will do some good.
Just wanted to let everyone know that it is possible to overheat an amp that is mounted in the same area,,,,98
Old Jul 21, 2001 | 12:59 AM
The_Headless_Horseman's Avatar
Just remember your amp needs room to breath, only after a few minutes of use, an amp can reach a high degree of heat, just remember having it in a closed up position might lead to fire, and we don't want that.
