How to change from 4omp to 2omp
Old Jan 16, 2001 | 02:02 PM
blackfordF150's Avatar
Post How to change from 4omp to 2omp
I have heard of people talk about droping to to omp stable and even 1/2 omp with the set up of there subwoofers.
Can some one tell me what exactly this does and how to do it, Do i need to rewire my subwoofer or what do I need to do.
Please help.
Old Jan 16, 2001 | 09:44 PM
Silver X's Avatar
Registered User
Post
You need to have a dual voice coil sub. Some subs now are coming with single 1ohm,2ohm,3ohm etc...or dual 2ohm, etc. But alot of them come in dual 4ohm or single 4ohm. I think the JLAudio web site gives a good tutorial on it. Most manufacture sites have something to give you an idea of what's going on.
My truck at:
http://www.streetscenemag.com/ViewOw...?ProfileID=202
Old Jan 17, 2001 | 01:10 AM
Lok N Load's Avatar
Cool
When you bridge you're amp, you have a positive speaker terminal and a negative speaker terminal. All you have to do is wire the subs in paralell, all the positive sub wires to the positive speaker terminal and all the negative sub wires to the negative speaker terminal. You must be sure you're amp is 2 ohm, 1ohm, 1/2 ohm stable, or whatever you will be running. The impedance is pretty easy to figure out. 2-4 ohm subwoofers in paralell=2 ohms. 4-4ohm subs=1/2 ohm. Hope this helps.
Lok
1997 F-150 Supercab 4X4,Royal Blue,4.6 V-8, Tow Package,3.55 LS,
K&N FIPK,Performance Accessories 3" body lift,Superchip,
Gibson Supertruck Exhaust,Smitty Nerf Bars,
265/75-16 Wild Country Traction Radials,
Alpine CD,Alpine 5 Channel Amp,PPI 5 X 7's,
Boston 10" Sub
[This message has been edited by Lok N Load (edited 01-17-2001).]
Old Jan 17, 2001 | 07:57 AM
Silver X's Avatar
Registered User
Post
Ooops forgot about useing more then one sub, thanks Lok N Load. You can really get ohm crazy with more then one dual voice coil sub. Definitly make sure your amp can handle whatever ohm load you want.
Old Jan 17, 2001 | 07:47 PM
Post
So if I have 3 subs and I hook up all my positive to a positive and all my negatives to negatives what does this cause.
What does it do?
I guess I am still a little confuse.
Old Jan 17, 2001 | 08:43 PM
Silver X's Avatar
Registered User
Post
What brand/model sub are you useing? most likely they are single voice coils and 4ohm each? Here is a good site for you. http://go.to/bcae
Old Jan 18, 2001 | 06:13 AM
Lok N Load's Avatar
Talking
If you've got three 4 ohm subs you'll come out with an impedance of about 1.3 ohms. This is OK if you're amp is stable down to that. Most of the time when people run three subs, they run either three six ohm subs for a 2 ohm load, or three 12 ohm subs for a 4 ohm load.
Silver X,
Yes it can get crazy, but if you have four 4 ohm subs and wire both pairs in paralell (2 ohm load/pair) and then wire the two pairs in series to the amp, you come out with a 4 ohm load. Thats the kind of wiring scheme some of these guys who are running 12 and 14 subs use.
Lok
Boston 10" Sub
Old Jan 18, 2001 | 02:26 PM
Post
Thanks for the site, its is very clean and simple site to get some knowlege.
That site really help,,,,
THanks again.
