Rear wall vents
Old Mar 23, 2009 | 08:03 PM
Windsor's Avatar
Rear wall vents
I installed an amplifier on the rear wall this weekend and have been driving around without the rear seat so I have access to the crossover and volume settings. I also haven't reinstalled the rear carpet or whatever you'd call the cover. You don't notice it with the rear seat in place, or at least I didn't, but those rear air vents let in a ton of road noise. What have some of you done to quiet it down. I'm thinking a thick piece of foam between the rear mat and the vent might help and still allow air flow. I did a search, but I don't see this issue coming up, at least with any of the words I've used.
Old Mar 23, 2009 | 08:47 PM
JJDH's Avatar
dont block them, causes hvac issues,cab has to have em. i put pics of what i thought was best in my gallery.... some kind of cap or smthn that is open on the bottom,
Old Mar 24, 2009 | 07:03 AM
Windsor's Avatar
The foam is breathable, but it could restrict the air flow to some degree.
Old Mar 24, 2009 | 07:24 AM
JJDH's Avatar
all u can do is try, if the cab doesnt breathe it wears out your hvac faster
Old Mar 24, 2009 | 10:05 AM
Windsor's Avatar
I usually run my A/C on recirculate anyway. That shuts the vent door in the front. But I turn off recirculate in the winter for the heater. I'll post negative results if it doesn't work right. That's for the replies.
