Sub box port?
Remote wires?
For those of you guys running multiple amp setup, how do you guys run your remote wires? Do you guys run two wires from the headunit or just run one wire and then splice it for the other amp?
Thanks,
Beto
Ps - Messed up on this post and put it in wrong section thats the reason for the wrong title.
Thanks,
Beto
Low_e_Red has mentioned before, I do believe the max output from a head unit remote wire is 500mA. It may be Alpine that is very sensitive to the amount of current drawn. Without finding it for you right now, the safest thing to do would be to use a relay just so you are not stressing the remote turn on of your head unit.
