quick question
Old Jan 11, 2009 | 12:38 AM
gatorbait10's Avatar
quick question
i have a 4ch amp on the back wall with a 4 gauge power wire. If I added a mono amp, would i need a distribution block or could i just run another 4 gauge power wire to the battery for the new amp? What would be better or does it really matter. Thanks
Old Jan 11, 2009 | 06:49 AM
Impact9's Avatar
Your going to need to run a larger fused power wire (0/1 gauge) to a distro block then split there to your current 4 channel and mono amps. Always better to have to large a power cable than not large enough. Check http://www.knukonceptz.com/
Old Jan 12, 2009 | 09:01 PM
RED4X4's Avatar
That or run another 4awg wire from the battery.
Old Jan 13, 2009 | 04:00 AM
Low_e_Red's Avatar
Depends on the amps being run. It may be smarter to do it a different way...
Old Jan 15, 2009 | 03:57 PM
okay well one of the amps is a Kenwood KAC-8104D 500wRMS and then a Powerbass 4-ch. amp (400.4) to my door speakers (already installed). If I could just add another 4-gauge wire from the battery like red4x4 said I will.
Low, what way would you recommend?
Old Jan 16, 2009 | 02:27 AM
Low_e_Red's Avatar
2 gauge would be a minimum if running together. Otherwise a seperate 4 ga is necessary for each wire.
Old Jan 16, 2009 | 03:20 AM
RED4X4's Avatar
Might as well run 0awg if he wants to run one wire off of the battery considering the price of 0awg and 2awg is relatively close.
Old Jan 16, 2009 | 04:07 AM
Low_e_Red's Avatar
Do you happen to notice I said minimum. Yes, he can run larger if necessary. But I got it handled, thanks...
Old Jan 17, 2009 | 01:51 PM
thanks guys i think im just gonna run another 4 gauge from the battery as im on a tight budget
