Interesting issue...
Old Jan 8, 2009 | 09:15 PM
guitarman502's Avatar
I have been fighting this issue for a long time now. Had a JL 500/5 go bad on me, which I attribute to also killing my PXA-H701... long story there.
ANYWAY, I know have an ARC ks900.6. I am currently getting a popping noise through the passenger side rear speaker on start-up, then alternator whine coming through the front channels.
After spending a while on the phone with ARC's tech support, the guy said he had an F150 and with the quiet metal, it doesn't provide a good ground and he recommended grounding to the frame.
My question is, before I go through the work of doing all of this, is this a possibility or anyone else experience this?
current setup is W200 --> ks900.6 ---> MB Quart QSD 216's (front) ---) MB Quart Discuss (rear) ---> JL Audio stealthbox (sub)
Old Jan 9, 2009 | 03:30 AM
C. Whammy's Avatar
if the noise is just from the front speakers, then it could be a problem with the RCA's. make sure they are grounded.
try switching the front and rears and see what happens
Old Jan 9, 2009 | 04:34 AM
Impact9's Avatar
I grounded my amps to the frame and I'd say it's about the easiest thing you can do.
Old Jan 9, 2009 | 10:21 AM
ARCuhTEK's Avatar
I am getting ready to do my audio install in my 2008 F150. Could you tell us where and how you did the ground to frame in your truck?
Thanks,
Old Jan 10, 2009 | 07:57 AM
Impact9's Avatar
get a ground distribution block and run your grounds from you amps to that. Then use a fat 0/1 cable run from the block through the rear cab vents down the the frame with a terminal lug on the end. I used the gold plated crimp type and found a bolt that was right there on the frame that would hold the terminal. So I sanded that spot up and made the connections. Make the connection short as possible and it should be fine.
Old Jan 10, 2009 | 01:22 PM
mSaLL150's Avatar
I grounded my amps to a chassy bolt right behind the seat bracket and i have zero whine or popping.
Old Jan 10, 2009 | 09:14 PM
See, mine's on a chassis bolt behind the rear seat also.
Old Jan 11, 2009 | 06:59 AM
mSaLL150's Avatar
Did you clean the ground area? i sanded and really scraped/cleaned the area on/surrounding my ground bolt to make sure i got solid current flow.
Keep in mind, i have 3 amps now, and w/ the big 4 upgrade and deep cycle battery, still zero problems.
