Proper Gain Settings
Old Jun 12, 2008 | 03:53 AM
C. Whammy's Avatar
Ok, thought i would just start a new thread for this one
so, i downloaded an excel sheet that has a bunch of calculations for suggested power cable size, alternator power, and gain settings
it says to put in a 60hz audio track, turn up the HU volume to 75-80% of the max, set all bass and EQ to zero/flat, hook up a multimeter (set to AC) to the channel being used and change the gain settings until it reaches the prexcribed voltage
for 1500 watts at 4 Ohm (what i will soon be running) it says 77.46 volts
is this a good method?
are there any less complicated ways or just a general rule of thumb?
Old Jun 12, 2008 | 03:58 AM
C. Whammy's Avatar
gain is one thing that has never really been explained to me in full, sorry if my lack of knowledge upsets anyone
Old Jun 12, 2008 | 11:34 AM
abervintageman4's Avatar
i have heard this same method but i have yet to try it
Old Jun 12, 2008 | 12:22 PM
Low_e_Red's Avatar
Read here for how to: https://www.f150online.com/forums/sh...y%2C+pro+gains
Old Jun 12, 2008 | 01:21 PM
C. Whammy's Avatar
ok cool
do you think the way i listed would be worth trying?
Old Jun 12, 2008 | 06:31 PM
Bartak1's Avatar
The way Low suggested is a great way to do it to get every last bit out of your amp before you start clipping.
The way you mentioned also works just fine...not quite as accurate, but it still works fine and its actually close to how I do it.
With a good amp, there is usually actually a little more to be had after you set your gains this way, but its hard to tell how much without the proper equipment, or doing it Lows way.
If you have a crappy amp that is overrated, you will most likely start clipping the amp by the time you reach your target voltage, using the DMM method.
Old Jun 12, 2008 | 08:23 PM
Low_e_Red's Avatar
The reason I would do it my way, is because of build quality. Even with the most stringent quality control there will be differences in the amplifiers and what they are capable of. For instance RF and KKR test every amp before it leaves the factory. I have seen 2006 Kicker 1000.1 go from 998 to 1323w @ 2 ohms before. So if you use your way, chances you will be either be starting clipping or not getting all your power.
Old Jun 12, 2008 | 08:26 PM
C. Whammy's Avatar
how are you supposed to tell when your subs start clipping?
do they just sound like **** or what?
Old Jun 12, 2008 | 08:52 PM
Low_e_Red's Avatar
Trying to hear clipping in Subwoofers is much harder. And normally they can take a good bit more abuse.
I recommend doing it my way and running a 1kHz track and getting the gains almost tied down from there. Then switch over to the 40Hz and working off of that. (50 and 60hz will also work). Keep in mind you will be using a small handheld 10w radioshack amplifier with a spk built in
Old Jun 12, 2008 | 10:03 PM
Bartak1's Avatar
Exactley!
Old Jun 13, 2008 | 01:04 AM
C. Whammy's Avatar
Alright. i appreciate the help guys
