Mono Amp Wiring Help
Old May 12, 2008 | 03:53 PM
fdimeroller's Avatar
I have a JBL GTO 1201.1 and a 15" RE SX with Dual 2 ohm voice coils.
[i have a install thread somewhere]
To my knowledge, the amp is not 1 ohm stable...right? So I am currently running the setup at a 4 ohm load. The speaker is not as loud as it should be. So i tried something different [not permanent]. I ran the positive & negative wires straight to the amp from the sub. I dont know wat that ohm load equals out to, but it was much louder. However, i re-wired it to 4 ohms, because i didn't want to mess anything up. Is it alright to do it like I had it? Should I find a more powerful/1 ohm stable amp? Help please, thanks
Old May 12, 2008 | 10:28 PM
jay5150's Avatar
If you hooked it up positive to positive and the same for negitive, then you ran it into 1 ohm. That amp is not 1 ohm stable. You have to run it at 4 ohm.
Old May 12, 2008 | 11:27 PM
1bad86vmax's Avatar
Unless you buy another sub , then you can run it at a 2 Ohm load .
Old May 13, 2008 | 12:09 AM
no i dont have it ran 1 ohm. I am runnin it @ 4 ohm. But its not as loud as it should be... heres how its ran:
4 ohm right? (yes my mono amp has 4 connections)
and here's how i wired it earlier when i was jus messin around & it was much louder:
of course red is + and black is - . those lines indicate my speakerwire. my exceptional paint skills
Old May 13, 2008 | 12:11 AM
but that defeats the whole purpose of runnin this system....i wanna run this sub. unless i can find a dual 4 ohm SX then i can run it @ a 2 ohm load.....
Old May 13, 2008 | 12:35 AM
marcolarco52's Avatar
that amp you have is capable of 2 ohms which will work with that sub and give it more power which will achieve what you want.....louder
Old May 13, 2008 | 12:37 AM
how do i wire a dual 2 ohm sub for 2 ohms? diagram please?
Old May 13, 2008 | 01:22 AM
didnt see it said dual voice coil....honestly i dunno how to wire a 2 ohm dvc sub to 2 ohms on that amp...hmmmm maybe someone else
Old May 13, 2008 | 01:53 AM
yep. dont think its possible.....
Old May 13, 2008 | 08:46 AM
1bad86vmax's Avatar
The reason it was much louder , is because you were running that amp at a 1 Ohm load , verses how you have it now at 4 Ohm . The amp will put out alot more power at a 1-2 ohm load than it will at a 4 Ohm load . However it will only play high volumes for a short period of time at 1 Ohm , before it shuts down . You cannot run that one sub at 2 Ohm . Thats why I suggested finding another 2 Ohm DVC sub (just like the one you have) so you would have 2 . Wire the coils in series and then the subs in parallel , for a 2 Ohm load .
Old May 13, 2008 | 11:51 AM
oooo. that helped a lot, thanks. but i cant afford another one of those & so if i get a 4 ohm DVC that can be ran @ 2 ohms right? idk, gotta figure sumthin out.
Old May 13, 2008 | 01:54 PM
1bad86vmax's Avatar
Correct , you would wire it in parallel like this .
Old May 15, 2008 | 12:41 AM
so US Amps and RE Audio are a joint company. How do you guys think at US AMPS XT 2000D will work with it? http://cgi.ebay.com/NEW-US-AMPS-2000...QQcmdZViewItem
i can buy it tonite if i hear enuff good feedback thanks
Old May 15, 2008 | 01:24 AM
actually i bought the 4000D
EDIT: that being said, does anybody wanna buy my JBL GTO 1201.1??
